HP Pavilion dv9000z Notebook Logo
Anonymous Posted on Sep 22, 2012
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
All of a sudden it takes a longtime to get past bios screen and once it is up, there is no wireless signal and wont go online via lan. Virus maybe, but it won;t let me boot up via installation dvd....pleeease help if u can
Anonymous
Level 3:
  • HP Master 2,878 Answers
  • Posted on Sep 22, 2012
Anonymous
HP Master
Level 3:
Answers
2878
Questions
0
Helped
487377
Points
8243
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
2 Related Answers
Anonymous
  • 2004 Answers
  • Posted on Jun 04, 2009
SOURCE: Screen problem HP DV9000
Please perform system restore on your pc. Restore to factory default and remember to backup your documents.
rate this
Anonymous
  • 17 Answers
  • Posted on Jun 10, 2009
SOURCE: hp pavilion dv9000 screen and factory settings
*Actually*, with regards to the screen issue, software CANNOT cause a failure when the display assembly is physically moved....The two possibilities are the LCD harness (video cable) part# 432962-001 OR the actual LCD itself (part# LP171WP4 (TL)(03) for most models). My money's on the cable, not a stupid driver...
Ze4610 won't boot past HP logo
The hard drive has issues, the next step is to have it tested for possible replacement.
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
2answers
Laptop is having trouble booting up.
HP Limited Warranty Service Enhancement - HP Customer Care (United ... If you own an HP Pavilion dv2000, HP Pavilion dv6000, HP Pavilion dv9000 or Compaq .... Willthere be a future BIOS release that does not make my notebook fan remain ... Black Screen Error Messages that may Occur During Startup or Boot ...
h10025.www1.hp.com/ewfrf/wc/document?docname...lc=en...
HP DV9000 won't boot up past the HP splash screen, can't enter bios or access boot menu. It just keeps starting over, freezing, then starting over again.
I think your hard drive has failed. It keeps searching for the boot sector. The boot sector is broken so the hard drive keep starting over to search for it.
Hank
2answers
HP PAVILION DV9000 COMPUTER STARTS BOOTING UP AND THEN STOPS.
mostly its because vga(Graphic) problem.
i can fix it if u want, u have to send me the mainboard.
Opened my lap top HP dv9000 black screen sounded like it was running, I shut down then tried to reboot,starts to reboot then cuts off then tries to reboot and continues this cycle
Try starting the laptop in safe mode.
This is done by pressing F8 while the computer is starting. You will be presented with an option screen and should in the first instance choose safe mode. If the laptop boots you can then check the hardware for faults. If you are not getting past the initial bios boot screen it would be worthwhile downloading the latest bios firmware from the HP web site and installing this.
My HP Pavilion DV9000 is having boot up problem
hi
this is nothing to do with system crash.
> Take out the battery and the adapter from the notebook hold the power button for 30 sec
> Power on - ASAP tap on F10 - There if you are using vista press F9 to load the bios defaults and press F10 save and exit
With regards
Wrong bios
The # 443694-001 refers to the cd set. You need to know which DV9000 you have. On this link you will see all the DV9000 models.:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=DV9000+443694-001&submit.x=6&submit.y=4
You will need to use a friend's computer for the following.
Once you find the correct firmware, You can make a bootable CD by using Nero or Roxio burning software,these are the most common on computers nowaday.Once you make the bootable CD, you will have to set your laptop to boot from the CDROM. Then boot the CD you made and run the firmware update.
I don't believe you would be able to get a USB flash drive to boot in this condition.
Good Luck
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
