Kodak EasyShare V1003 Digital Camera Logo
Anonymous Posted on Jul 14, 2017
Kodak v1003 screen has no data (grey screen)
The first screen on this camera was damaged and replaced a few months ago. Just yesterday, I recharged the camera, and when I powered up, the view screen came up gray... no picture, no menus, nothing. I popped the casing, removed the screen and carefully reseated the flex tab connector thinking maybe it wasn't seated properly, but it still comes up gray (lit up and getting power, but nothing else). Any suggestions?
Marvin
Level 3:
Top Expert:
  • Kodak Master 85,242 Answers
  • Posted on Jul 15, 2017
Marvin
Kodak Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29037082
Points
266281
The cost to repair is about the same as the cost to replace and you must send it back to Kodak for repairs. About 6 weeks turnaround.
1 Related Answer
David Shaub
  • 2994 Answers
  • Posted on Aug 06, 2009
SOURCE: Kodak Easy Share V1003 -Screen stays a grey blue color.
A new screen is availably from virtualvillage dot com for about $45. I replaced one last week. It only takes 20 minutes and a small screwdriver. The ribbon cable is held in by a flip up lock at the main board.
Kodak Easyshare V1003 will not charge I have had it plugged in all day
The rechargeable battery will more than likely need to be replaced, if it won't charge it is time to replace the battery.
Kodak v1003 screen has 3/4
tap the screen and see if any changes happends.if not, you need a new display.on rough impact such issues usually apears....sorry for my english
Every time I turn the camera on, it takes 2 to 3 minutes to come on and always makes me verify date and time. Why?
This usually indicates that your rechargeable Li-Ion battery is starting to lose its ability to retain adequate charge due to age and usage (about 500 charges or 18 months of 'normal' use). Try putting a new rechargeable Li-Ion battery.
Hope it helps!
2helpful
2answers
My LCD screen has a dark spot
The screen must be replaced. To do it yourself, the screen will cost around $40 from virtualvillage dot com. I just did one. It took about 15 minutes. The ribbon cable is held in by a flip up lock on the main board. Otherwise, it's just remove the screws around the case and pull the bottom edges outward first.
virtualvillage uses Pay Pal only.
V1003 will not power up
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. First try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
White Sreen
unfortunately it would appear to be a CCD or main board failure.
If the camera is out of warranty (as this should be covered) my best suggestion is to pick up one off ebay with a broken screen and put your screen in it, broken screens are common on these cameras so they go quite cheaply, far cheaper than kodak would charge for repair and the swap is easy.
There are several searchs to try "parts v1003" "spares v1003" "Faulty v1003" "repair v1003"
Best of luck
Kodak easy share v1003 with broken lcd how i can fix this cheap
Sirs I have a Kodak easy share v1003 showing the screen completely white. How can I replace it... seems that I already find the spare part in e-bay. Can I do this replacement by mayself?
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
