Insert disc and I get Disc Not Finalized
Don't know what a fwc100 is but you need to finalize the disc per procedure outlined in the manual- that writes the TOC (table of Contents) to the inner part of the disc which the unit reads right after the disc is recognized by the laser. If the disc is not finalized this TC is not written and you have a disc that can still be written to in certain burning units.
SOURCE: TEAC CD-P1260
Identical problem with my 4-month old player. I mailed the unit to the repair shop noted on their web page (Montebello, CA). They "re-soldered a loose connection" and made a "mechanical adjustment". I got the player back in two days. It now works fine (again). Under warrenty; no charge.
SOURCE: It wont finalize disc just says disc error
Sounds like a duff (dirty or scratched) disc. Try another one.
SOURCE: MY CD PALYER DOES NOT WORK. ''DISC NOT FINALIZED'' IS DISPLAYED.
If your CD player has been working for many hours and cleaning the lens didn't help, then the next thing to do is changing the spindle motor (the one that spins the disc), since the brushes and the commutator get dirty/oxydized with many hours of performance.
The motor can also be cleaned, but it's kinda complicated and delicate to do it, so you might want to change it instead.
The same holds for the slide motor (the motor that changes the position of the laser pickup).
To clean the motor you need to desolder/remove it and open it up (you need to bend out the clamped parts on the motor housing to release the cover - also, mark the position of the cover so you can put it back in place in the same position as it was prior to opening it - some motors have an indentation so that the cover fits in place in only one position).
Then you need to remove the cover (this is a delicate procedure as you can easily damage the brushes).
You can clean the brushes and the commutator using a long pointed scalpel - gently scrub away the brownish/black residues on both the brushes and the commutator.
Now you need to put the motor back together, taking care not to damage the brushes when you put the cover back in place (kinda tricky but it can be done).
After closing it, see if it runs smoothly, you may want to try and run it on some 3 volts - it must run quite silently, with no more than a gentle humming sound.
If it runs ok, you should use a tiny flat screwdriver and a small hammer to bend the housing edge back onto the cover to fix it in place (basically, you need to rehammer back in the clamps that held the cover in place, this is also a bit tricky and delicate thing to do).
Now reinstall/resolder the motor back in place (motors on some brands/models can be worked without removing them).
Well, i've just told you how i repaired quite some CD drives which were virtually dead, i'm actually still using a yamaha which is more than 15 years old (i myself have been using it for at least 10 years now), i got it as a scrap piece, it returned to life after the above described procedure and it actually works perfectly up to date.
Anyway, i guess the easy way is to simply replace the motors (they need to have the same axis dimensions and mount holes as the original ones, also they need to run on the same voltage - things to keep in mind when you are looking for new motors).
Hope you can get it working...
good luck
3rq8 (Triarcuate)
SOURCE: Hey! i just recorded a press conference, at the
Once it is finalized thats it.Unless it is cdrw.I think you got everything in there tho. I guess it just did it in 8 eperate tracks
SOURCE: I have a marantz cd re-corder but I insert a cd rw disc or cd r
check the manual for what types of discs you can use.
