Brand new machine, operator error in that I can't switch to the decorative, quilting, or practical stitches - it will say 'l' or 'k', but it sews a straight line and not the corresponding stitch. l don't know what I am doing wrong - thank you - Sage
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
SOURCE: How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions [email protected]
SOURCE: how do you set the zig zag stitch on a Jones
Change the needle first it may be slightly bent, if you are sewing on fabric that creates static you will need a special needle, failing that you may need to retime the machine.
SOURCE: I have a Montgomery Ward sewing machine that does
Did you get a solution to this? I have the same problem...
