White screen problem
Hi ,
replace your LCD is the best solution to your problem...but before you do that ,test your phone like this maybe its software problem...dial 112 or any emergency number in your location...if you hear a voice of a operator its is lcd problem ...but if you wont connect to the operator or you hear nothing its LCD or display problem...
My nokia 2730 white screen solution
Nokia 112 on off.
SOURCE: Nokia 2730C Countery Code Requierd
Hi,you can unlock your mobile by unlock codes and for codes you can try your current provider or can get it from online providers..once i got unlock code for my mobile from theunlockspot and unlocked my mobile..you can too try getting codes for your mobile and get it unlocked..but before that check whether unlock codes for you country and provider..
SOURCE: when i switch on my
Try to reboot the phone without insert your Sim Card and Memory Card for 3-4 times.Even if there is no result you need to flash/update, so contact mobile tech or follow the instruction what I have given here.This is the best ever other than Updating via PC suit/Ovi suit.
First download and install
Pheonix from this link. Nokia
Phoenix Service Software 2011 - Download secondly Download flash file from this link 2730 file and install it to C / program
files/pheonix.. after finished this installation open pheonix . Inside the
interface at the> top left
<there you see "File" click there and choose "open
file" and then select the approprait Product type i.e
"which is written on the back panel inside the battery of every Nokia(Type
RM-000).After doing this again at the left top count from
"File"1..2..3..the 4th one is "Flashing" press there,
when you click there you'll see three sub-menus, just select the "Firmware
Update" again you'll see another interface. Look at the product code
there should be blank and put your "mouse tool" at the straight end
from the "Product Code" there is a Button and
choose the code which is written in the back side of your phone. e.g CODE:0000000.if
the same code does not found just take one which is higher. After this you can
see "Dead phone USB flashing" click that box. Now this is the
last stage... Connect your phone with the USB to your PC and let
the driver install ...wait for a moment.(If
your phone working).Lastly after just finished (In case your
phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish"
button after this, a message will prompt you "press power botton"
etc. insert charger or press it and wait
until the phone will Restart automatically in normal mode 10-15 minutes. If you
cannot understand just leave a Comment. thanks for visiting fixya. Good
luck.
SOURCE: nokia 2730c-1 how to unlock using phoenix service software
Unlocking a mobile phone using unlock code is more safer than software unlocking. So i suggest you to unlock your mobile using unlock code. You can get the unlock code easily from your network provider or from any trusted vendor online. You can visit http://www.mobileunlockguide.com/nokia-2730-classic to get free unlocking instruction guide.
