Help...i cant delete songs, using windows media player
Hi. The minimum requirements of your Sansa E250 is Windows XP and above and Windows Media Player 10 and above. If you're using Windows Media Player 10 or above, your Sansa E250 and its contents should appear on the right pane when you click on the "Sync" tab. You can right click on a song and select "Remove". The songs will be erased permanently from the player. If your songs do not appear on Windows Media Player 10 or above, it is possible that your songs may have been saved on another mode. Your Sansa E250 comes in 2 modes: MTP and MSC. Songs saved on one mode will not be seen by the other mode, and vice versa. There are 2 ways to delete songs from your Sansa E250: By browsing the folders containing the songs, or by formatting the player. You can switch modes by navigating your E250's menu using the following: Menu >> Settings >> USB Mode Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio button Deleting Music files under MTP Mode: 1. Your player should appear as a Sansa E250 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player. 2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder. 3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it. 4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player Deleting Music files under MTP Mode: 1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E250" 2. Double left-click on this drive letter to browse the player 3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files. 4. Delete the music files you want, and they should be removed from the player Deleting files through Format: 1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode. 2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process. 3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears. 4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen 5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player. I hope this helps. :)
The Other Way is That YOu can open your Players Drive and Delete each song. you do that by clicking my computer then tthe player, then the music folder then right click the song and choose DELETE . And If you want to delete everything at one whole time just right click on the player and Choose FORMAT.Hope This Works.
Go to tools and click Folder Options. Then change the settings to unhide the hidden folders. Go to music and delete those songs.
OMG I LOVE YOUUUU!!
Thank you very much guys :]
Thanks this worked Great
I plug my sandisk mp3 player and all the song i delete from the past are back and it won't go away
Thanks i finially got it this realllly works!!!
Thank you! i've been trying to figure this out for months and finally the songs i never wanted r gone!
THANK YOU IT WORKED I HAVE SEARCHED FOR WEEKS!!!! THANK YOU!!!
SOURCE: Deleting songs from Sandisk
i don't no how to delete music off my sansa mp3 player with windows media player
SOURCE: how do you delete songs off of a sandisk sansa m240 music player
In My computer right click on the mp3 player and select format..then it will delete all songs..
it won't let me delete songs off my mp3 player so how do i do it!!
some songs come up with a red box saying it has to be syncrinized to the device, and when i gets there my whole mp3 player freezes up.
im tryin to delete songs from my mtp player because i ran out of mb and i want to put on diferent songs. i juss cant seem to figure out to do that.
and if you have the solution email me at: [email protected]
i have a e250r do the same rules aply
How does one switch between the two formats?
I can't seem to find out how to take songs off of my sansa e250
i cant take of songs off my e260 mp3
too many repeted songs
I have a Sansa C250 and I have Windows Media Player but can't seem to delete all the Songs from it.. Please help
can't delete songs
I have sample songs that i don't even listen to but cant delete them i cant even delete songs that i put on myself
how to delete the song that came with my media player
i cant delete the songs off my sansa e250 mp3 player
i dont know how to delete songs off my mp3 player
i cant
Now here is my problem: I have followed and tried all the sansa forums on deleting these files. The files are the ones that were downloaded with the Rhapsody trial period.
Now when I connect the drive either as the Sansa E250R in Rhapsody mode all the files are in the MUSIC directory and I can delete them but when system is turned off then on they are back. When I try to format the sansa the message comes back “Format incomplete”. I even deleted the 5500 file that was referenced somewhere.
The same thing happens when I put it in PlaysForSure mode and it is displayed as PPI NAND. Deleting files and trying to format.
I have also run chkdsk /f and chkdsk /r when it was showing up as the E250R on the E: drive.
Now when it is in PlaysForSure mode and I try and format the screen on the sansa shows the word “writing”; however, the FORMAT error is “The device was unable to complete the format”. When disconnected it states that not enough space for MUSIC DB. Please free 6MB. The displayed on the screen is ”Database had to be repaired. Connect to your PC to refresh database.
I am using Windows XP SP2 to do all these things.
The sansa e250r was purchased for Christmas 2007 and connected to Rhapsody on 12/27/2007 and the subscription expired on 01/26/2008. I have since been trying to delete these files or format the sansa on and off since then to make room for new music.
Whenever it is turned on whether or not the mode was set to Rhapsody or PlaysForSure this message “ALWAYS” comes up. Your subscription tracks have expired. Connect to your PC to renew. It is these subscription tracks that I cannot get rid of.
I have even deleted the .rax files and they come back after power off then on.
When I try a recovery mode it comes up with: Enter USB2.0 MSD mode. I am not sure what I need to do at this point – what I need to do for a recovery. The computer shows it is a 16MB- FORMAT and properties show Used 48.0 KB and Free Space as 15.2
cant delete music from device
The songs are copied multiple times and whenever i click to play the song it show that the song is 0 minutes long.
i used to be able to add and delete songs... but know i can only add... how do i delete unwanted songs??
my windows no longer reads my sandisk because i need to remove 6 dbs of space. but i can't remove it without windows. is there away to remove songs straight from the sandisk?
Hi, I have an expired rapsohdy subscription and I can't delete the songs off of my sansa e250r player. I can load songs onto it via windows media player but it says I need to connect to my computer to clear up the other songs. Problem is, I have a new computer now so I don't have any of the Rhapsody downloaded on this one. Is there any way at all to get rid of these expired tracks???
Please Help.
i bought my sansa from a friend and it already has most of the memory used up with his music. there's only enough memory for me to add on a few of my cds. i want my music on it, not his. when i open the folder on the computer, all i can see is the music i downloaded into it, not the ones that were already there. also, there are a lot of pictures on it that i want to delete. there is no way to delete them one by one on the mp3 device. is there a way to just wipe the whole thing and start over?
well i bought a sandisk of a friend and the whole memore is full with pics amd wierd music so i was wondering what can i do to delete all of the pics and music and start over but with the music i like my music and my pics..but right now i cant do that because of the memorie full proble so if you can tell me how to like restar the whole thing it will be great
thanx..
can you just tell me how to delete songs
i have a sansa e250 that will not let me delete songs. it also wont recognize the device if it is in the MTP mode, but that is the mode that, at first let me add and delete songs. so all the songs are saved on that mode. please help the memory is full and im tired of these songs and want new ones.
WHEN I OPEN THE MEMORY ON THE DEVICE IT DOSENT HAVE A MUSIC FOLDER EVEN THO IVE FORMATTED IT MADE A NEW MUSIC FOLDER IT WONT DELETE SONG ALLS I CAN DO IS ADD SONGS PLEASE HELP!!!
eMAIL:[email protected]
i delete songs on the mp3 player i went to all of the icons on windows media player and some songs wont even show up on windows media player and some songs still are there please help me!!!!!!!
contact me at [email protected] if you know what my problem is.
Whenever i connect my sansa to my PC and look at the music folder, i got folders like "h" "r" and so on. i can't delete these. how do i delete these and be with just my songs?
Solution link . . . http://www.Sansae250MP3Player.com
