KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
Posted on Feb 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Plastic film over hidden control panel
We have a Architecture series KitchenAid KUD01-1 series dishwasher with the hidden control panel at the top of the door.  We have had the plastic shield over the buttons disintegrate over one of the more frequently used buttons.  What is involved in getting this replaced?
MrFixitSTTL
Level 3:
Master:
  • Master 340 Answers
  • Posted on Feb 21, 2018
MrFixitSTTL
Master
Level 3:
Master:
Answers
340
Questions
0
Helped
166854
Points
1713
Clear packing tape is often effective but in a hot wet environment- it is not permanent, you may have to redo. Clean with alcohol swab first.
4 Related Answers
Anonymous
  • Posted on Jan 16, 2009
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Anonymous
  • 3 Answers
  • Posted on Jul 12, 2009
SOURCE: Kitchenaid dishwasher leaking from door
Check the screws on the pump cover under the lower spray arm (the spray arm is easy to remove, the screws are torx - maybe a torx 10 or 15, so a regular screwdriver wont work). They come loose on ours every 6-12 months and spray water at the door, causing it to leak all over our wood floor. I routinely tighten those screws now before they come loose enough to cause the problem.
Anonymous
  • 246 Answers
  • Posted on Aug 21, 2009
SOURCE: KITCHENAID DISHWASHER DOOR PANEL
www.applianceart.com has many options for you to choose from. They sell many different panels to put on your dishwasher. If you call them (678-727-4747 x32) they can also send you a metal stainless plate that is easily installed. I think the metal ones are around $99.99 and the other options are $39.99
Anonymous
  • 43501 Answers
  • Posted on Jun 01, 2010
SOURCE: Our kitchenaid dishwasher is not cleaning well
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Our KitchenAid dishwasher started making scary baby cry sounds. then a few months later the clean dishes would have a white film over them like dried detergent didn't rinse.
Hello Cindy;
My name is peter. I am a retired field service appliance technician.
You need to provide a model number so I can see what you have. The model number is on a tag on the front face of your dishwasher after you open the dishwasher door.
You may want to remove the bottom front panel on your dishwasher, run the dishwasher and observe. There are two clip pins on the top of the bottom panel. Push in with a putty knife or something similar. Pull on the top of the panel on both sides, then lift the panel up.
How do you control dd605i dishwasher when touch controls do not work? My wife saw the service man control the top panel using the front buttons.
This will only control the diagnostic service mode, it will not run a regular wash cycle.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Plastic dishes and utensils have white film on them
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Soap not fully rinsed from dishes, maytag quiet series 300
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Cleaned plastic cups and bowls have a greasy film on them
water heater temp to low maybe new elements clean internal unit screens cascade complete jel
Dishes on top are not coming clean-
heatman101
7helpful
Hidden control panel not accessible on dishwasher
no thats correct installeation of machine, its meant to be a "hidden" control. simply open the door, choose your options, press start and close door.
Feb 28, 2008 • Dishwashers
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
