Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Amana ptac i recieved a power cord replacement as per recall. did as instructions said. I did turn off master off/on switch on pc board. after i was finished I turned switch on/ closed cover and plugged in cord. the panel lit up and i pushed HEAT. cold air blew for abt 30 seconds and stopped and a clicking noise began. I unplugged cord and started looking for answers. can u advise? its less then a year old.
  • 3 Answers
You have the white wire on the wrong terminal put it on the same terminal as the red wire on the capacitor and you should be fine,
Posted on Jan 06, 2009
SOURCE:
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
Jun 19, 2010 | Amana PTH093B35AM Thru-Wall/Window Air...
Amana PTAC cannot be turned on.
sound like a thermister problem, however this may also be a circuit board problem, the system is controled by the outdoor board, check to see if you have a blown inline fuse in the outdoor unit, it will be under a red case in one of the wires.
Jan 28, 2010 | Heating & Cooling
Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Jan 23, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Ptac
You need a new control board. The relays go out on these. If your unit is less than a year old then you should still be under warranty. Unless you did not send in the warranty card, then the company only warrants the unit for 1 year after the mfg. date. You will need to provide the serial and part number to find out from Amana. The new control boards are much better by the way, and worse come to worse, they are only $130. Please let me know if this has helped in any way.
Dec 27, 2008 | Amana PTH123B25AJ Heat Pump Air...
PTC153B50AM REPLACED POWER CORD ON RECALL
First off, you need to unplug power from the unit before handling anything on it, not just the master switch on the control board. There is still live power being fed to the unit while it is plugged in!
Now, the clicking sound you are hearing is a faulty relay on the control board. You have to replace the control board. The new ones are available from Amana/Goodman Mfg.. You will find, assuming you have more of these, your other units are going to start doing the same thing. It will be the same problem. When they send out the new control board, make sure you program the board. They no longer come pre programmed. It is actually a huge improvement on the older control board upgrades. Hope this helps, I have 140 of these in my hotel, I know them all too well. Let me know if you have any other questions and please rate this as a fix ya.
Dec 25, 2008 | Amana PTH123B25AJ Heat Pump Air...
Ptac unit not heating, but fan,thermostat switch and ac is working. Please advise the solution to the problem. Thank you.
sounds like your control board could be bad,I'm a master a/c tech I work on these from time to time and I have more problems with the control boards,what brand is it
Nov 16, 2008 | Amana Heating & Cooling
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
361 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
WatsHVAC
Level 1 Expert
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
