My washer gets to the spin cycle, stops and shows a UE code. If I hit the play button it starts again, sometimes. Can someone tell me what to do?
UE code is an "unbalance error". Believe it or not, it is possible to unbalance a front load style washing machine. Usually caused by trying to wash smaller loads where the drum spins to try to distribute the weight evenly. With less laundry, you cannot distribute enough weight evenly around the drum and sometimes will cause an unbalanced load. If your problem is not a simple loading issue, it could be the balance sensor, loose wiring, or possibly the main control board. I hope this helps.
my washer shows OE is this similar problem?
I have had this issue as well,... but only with small loads of heavy items ( ex.1 pair of jeans). As described, load cannot be alanced & machine stops to save itself from undo wear due to the unbalanced load.
getting an u E code evan emty washer is leval
washer will start cycle then stops after 5 seconds=shows E 31 code call service
UE Code on an LG WM2277HS Washer... help!
