Thanks everybody for trying to help me. I found this cool website that shows just about everything you want to know about powerchair repairs ect. Check it out. Just copy and paste. ( http://www.easymedonline.com/troubleshooting-repair-mobility-scooters-power-wheelchairs-recliner-lift-chairs ) I was so excited I fell out of my chair and sprained my wrist.
SOURCE: 2 lights blinking on control stick. and chair
sounds like you need a new motor. 2 flashes indicates left motor.
SOURCE: Jazzy 1420 not 1170
sounds like the wiring from the motor to the controler is not making good connection, try unpluging motor wiring from controller box. Use a plastic safe elec. contact cleaner and lube spray on connections. water in the joystick can also cause this.
SOURCE: I just replaced the batteries
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
