What is flashing hoop with E inside it, error symbol?
SOURCE: husquvarna Viking Rose thread error
You need to see if the take up spring is moving freely when you are in these first 15 minutes (I assume the machine runs ok after 15 mins).
The take up spring is on the left side of the tension assy. When the thread is pulled up toward the take up lever, you should be able to look through the slot in the front of the machine and see a copper colored wire move up and down as the thread is pulled and released. This is the end of the take up spring. The spring is attached to the thread breakage sensor. If its movement is sluggish, it may cause the machine to falsely indicate the thread broke.
Sewing very slowly may cause this problem to stop. If the machine runs as minimal speed and then gives thread break indication when speeding up, the sensor interrupter is not moving fast enough and should be cleaned and lubed.
SOURCE: I am ready to embroider and a flashing hoop icon
Refer to your manual, it could mean the hoop is not making contact with the sensor or you are using the wrong size hoop for the selected design.
