When going to switch to av mode it remain locked ,i can't watch set top box chanell & dvd movie.a lock icon always appear ,my remote has no unlock button.
SOURCE: WATCHING TV IN AV MODE
Use the "DISPLAY" button on your remote control to remove it from the screen
SOURCE: My child pressed buttons on
These instructions should get your set unlocked, if not there is a number to contact omni for technical support, some times these locks may be a software issue. Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work. Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off. Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup. Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
SOURCE: RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
