SOURCE: will not brew a full cup
Mine started off this way, then quit running any water through. I overcame the problem with a reusable K-cup. They are available online and at some national chain stores for about $15.00. It's a little more inconvenient than K-cups, but better than throwing out a $150 coffee maker.
SOURCE: My keurig won't brew a full cup for the 10oz
This sounds like a water level sensor inside the unit. If it's under warranty... call Keurig and they might send a replacement... out of warranty requires you to open the unit and re-seat the harness that comes off of the water level array into a circuit board... low voltage thing...taking it apart is not easy, but I have explained it in another answer... for a B70 unit...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
SOURCE: My keurig machine wasn't brewing a full cup so I
do another descale..add more vinegar....run the entire full tank of water....you must have a big buildup of scale...
SOURCE: MY Keurig is about a year old and it won't
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
