My K810 mobile fell yesterday and since then when i put it on it only shows a white screen and does start. and when use the any key, suddenly comes white screen. please solve it
Sounds like a pressure injury! If u hhave warranty, then hurry and get it fixed! Probobly only the screen which needs to be changed! you could do it yourself if needed!
Hello, I think you mean Sony Ericsson K810 cyber shot,if it's so, then these problem happen when the flexible wire are damaged, its called FLEX too, these repair is simple and no expensive...
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Friend, it is only the LCD screen connection that maybe detached because that is the common problem i encountered as a mobile technician. Be sure that the flex connector is attached firmly on the mainboard. Just try to see it it and fix it. it will be good for sure. Just use screwdriver for mobilephone marked T6. good luck friend.
More than likely you will need to replace the display screen but before you do take the screen out and reseat the LCD connector. This will sometimes fix a white screen.
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
hi! its me kibbs! i think your mobile will be fell down! you want to change the mobile screen in mobile service centre! bcoz of that only your mobile gettin slow! And also service your phone in service shop!
Thank you!
