I am assuming this is on a DTU 16D nec phone. On the right side of the phone is a volume up and down button. If someone calls you, you adjust this while the phone is ringing. If you adjust it after you answer it controls the voice volume (what you hear through the ear piece) if you adjust it while the handset is down but there is no one calling you it adjusts the display contrast on the phone.
Lift handset
Dial 60
Dial off hook Ringing Volume code 1
press up or down arrow on phone
replace handset
SOURCE: Ringer volume
Adjusting the ringer will depend on the type NEC system you have. On the PRO II, Elite, and IPK just press the Speaker button and dial 601. The Phone should begin to ring and you can then adjust the volume with the up and down arrows.
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
I can't get the phone ringer volume to turn down.
