Many Jensen TVs have a parental lock that can be set to stop
children from watching certain television shows or channels. In order to
activate or deactivate the controls, you have to know the four-digit code or
parental lock passcode. If you forget the passcode or if the lock gets set
accidentally, you can still unlock the TV. •
Look at the screen. If you see a red key on the bottom of the screen,
press "Function" and "Mute" on the remote at the same time.
This will unlock the channel. Do this if you want to bypass the lock to watch a
certain show or channel while leaving the TV locked. All other channels will
remain locked and the TV will lock again when it is turned off. • Unlock all of the channels on the TV by
entering 0711 or 3308. These are the Jensen factory reset codes that will reset
the TV to the original factory settings. By doing this, you will loose any
information that you have stored in the TV, such as channel labels and
schedules. You will have to program the TV again by going through the entire
initial set up. •Call the technical support service number
in your owner's manual if neither of those codes work. A technician can help
you troubleshoot the television as the problem may not be the parental lock
feature. Have the model number and serial number of the TV available when you
call.
Turn on the TV using the remote control. In most cases, you will
need the original Jensen remote to unlock the TV if you aren't sure of the
unlock code. You can purchase an original replacement online if necessary.
• Take your television to a TV repair shop if
neither of the codes work and the TV locked by itself while it was turned on.
In this case, the TV may need to be rewired
This information is from the manual:
Child Lock can be used to prevent your children from changing options on control panel while the dryer is running. When child lock is enabled, all the buttons will be locked and Child Lock glows. To enable Child Lock, Press and Hold OPTION for 3 seconds, A single beep tone is heard and Child Lock is displayed on the status window. To disable child Lock, press and hold OPTION for 3 seconds again.
