My battery went dead,so i pushed my 2002 cadillac escalade 6.0 out into my drive way to get a jump. the alarm started going off and when i tryied to start the vehical the engine wouldnt turn over. i went and bout anther battery and put it in the vehical and the vehical still wont crank. there is also a blue flashing light in the top left hand side of the driver side. it looks like some kind of tracking dvice.what should i do
02 Cadillac Escalade makes a rubbing grinding and starts clunking jumping noise after I drive about 20 minutes it usually does it when I've been driving for a while when it gets hot.
You need to start by getting a code reader and checking for trouble codes (DTCs) in order to figure out what's going on. As far as low tire pressure is concerned, batteries in the TPMS (tire pressure monitoring system) sensors inside the rims have a fixed life - you will get warnings like this when the sensors need replacing, and if one has gone dead, you can expect the rest to follow soon.
You will have to get into the hood manually to jump the battery and the use the key less entry. Use a long flathead screwdriver and pop the hood latch. To do this simply push the latch horizontally with the screwdriver and the hood will pop open. Jump the battery and you will be able to get into your vehicle. I would then address the reason your battery dies if not replace it.
well the cadillac dealer is right when you pull the battery all codes are gone the best way to handle this is bring a battery down there put it and get your car out of there
Whats dose it mean went I have my service stability system light on and it dosent trun off .. I have a Cadillac escalade truck 02 All wheel drive hope some one could help me.......
