Your electronic wheel chair may have a joystick that's too tight, something may need to be loosened to allow for a more fluid motion.https://greatbritishmobility.co.uk/electronic-wheel-chair
I would put a large hose clip around it. If you have the old one, you can probably get a replacement from Home Depot, or contact the company for a free one.
Has this chair got power raiser for seat? if so check it is fully down or check down micro switch. These will not go fast with the seat raised. A safety option built in.
1 red + 5 green is left parking brake fault. This is a pretty generic code and can be something as simple as the brake/clutch lever is in free-wheel, or it can mean something more significantly wrong, depending on how it is wired in this model. (We don't work with Prontos a lot here.)
The M61 has an elevating seat. There is a speed limit switch which consists of 2 magnets that make contact under the seat on the seat post. If the 2 magnets are together then the chair thinks the seat is all the way down. If the magnets aren't touching it activates a safety feature in the controls which cuts power to the chair by 50% hence drives real slow. Try lowering the elevating seat down through the joystick controls. If that doesn't fix it then either the magnet switches on the seat post came unplugged or broke.
Yes it can. Release the clutch levers on each motor.The levers are located on each side of the chair sticking up through the plastic body, just rear of the drive wheels. The levers are quarter inch round rods with a black rubber boot covering the ends of the rods. The rods are either pushed forward to drive or pulled back to unlock the drive wheels.
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
