Canon Speedlite 580EX II TTL Flash Logo
Posted on Sep 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The E-TTL does not appear in my canon speedlite 580exII anymore, only shows Manual and Multi-, is it faulty now?
Doberman
Level 2:
  • Expert 261 Answers
  • Posted on Oct 04, 2012
Doberman
Expert
Level 2:
Answers
261
Questions
0
Helped
83833
Points
368
What camera model are you using?
Try this:
1. How flash on camera.2. How USB cable to camera to Window PC.3. Run my software (EOS Utility)4. Click on Camera Settings/Remote Shooting5. Click on flash menu.
Any questions?
[email protected]
4 Related Answers
Anonymous
  • 9 Answers
  • Posted on Nov 18, 2007
SOURCE: Canon SPEEDLITE 580EX TTL Flash Problem: Flash will not stay in ETTL mode
u can use the H sync button only with the camera set in semiautomatic or manual modes, it dosent work in AUTOmatic modes
A
Anonymous
  • Posted on Dec 22, 2007
SOURCE: Canon Speedlite 580EX
Buy the 550EX, it's cheaper
Master /or Slave = 550
Slave = other
Alexander
Anonymous
  • Posted on May 20, 2009
SOURCE: I have a Cannon EOS
I posted this over at POTN:
Bringing up a minor-aged thread; but I wanted to add some information that may help others. Here's the best I can remember of what happened earlier...
Tonight, I had one of my three 580II's sticking in TTL. I grabbed another 580II and got the same issue. Then, I grabbed another 5DII, mounted one of those flashes and everything was fine. So far, it seemed to be a camera issue. Out of curiosity, I took the flash that was working and put it back on the first 5DII. Again, the TTL sticks and I think it's more mount related than camera.
I was baffled and a little pissed, but in a hurry; so I didn't think on the spot to take a moment to go into the camera's menu and check settings. I can say that I did check all CFn's, the exposure comp and both flashes on both cameras and everything was fine according to the LCD panels (not screen) on all. I also hand checked all the settings on the flash(es).
Here's how to fix it... it's generally NOT a connection issue from what I have concluded. If you have a 580II sticking in TTL...
I can confirm that the ONLY thing that fixed the issue was to check the settings THROUGH the camera's menu. By doing so, I found the flash exposure comp was dialed down 2 stops on the flash in question - BUT it DEFINITELY was NOT showing this on any screen - either camera or either flash. Everything was set right on the LCD panels. (not screens - I generally only use those for chimping. :D) The result was images were near completely white. Shooting in any mode would not fix the issue. You could not compensate. Even adjusting the EC at cam had no effect - even in M. So, check your FEC THROUGH the camera's back screen. This is (and only) where you will see the issue if it's not a connection problem.
I do believe there's some kind of internal (software?) issue with the 580II's and that's how I remedied it. However, it did only happen on one camera. And while it only happened on that one camera, I can say that as soon as I changed the EC through the screen, it was fine - without touching the connection. I did not experience any loose connection; that's for sure.
From a little research, I found this is a fairly common problem with the 580II's and resides in nearly 100% of the time with the flash as it happens on multiple camera models. However, it's easily remedied if you do the above in bold. ;)
Just FYI and hope it helps.
edit: Just wanted to add that these flashes have never seen moisture and even the camera menu showed "ETTL" when it was in fact not showing that on the flashes screen. Anyway, look at the FEC in the menu. ;)
MIke
  • 685 Answers
  • Posted on Nov 24, 2009
SOURCE: canon flash speedlite 550 ex ttl
Send the flash back to canon for Service this is not something that can be fixed in this forum. Do not use the flash the burning smell indicated a potentially dangerous problem and fire hazard.
Canon 580exii speedlight, I want to only use the slaves, but they won't fire when I turn off the master
You didn't say what camera model you are using.
If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1
Two 270EX II must be set at Slave, say Group A & Channel 1
or
One 270EX II set at Group A & Channel 1
Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Send me a email, then I can help you much better.
[email protected]
Canon 580exii
check to see if the flash exposure compensation is not set to underexpose your shot.. this would be true in ttl mode
I need a manual for my canon 580ex flashgun
580EX:
http://downloads.canon.com/cpr/software/camera/580EX.pdf
580EX II:
http://downloads.canon.com/cpr/software/camera/Speedlite-580EXII.pdf
2answers
Looking for service manual for Canon speedlite flash 220EX Thanks
The service maunal will cost more than the flash.
What's wrong with the flash?
[email protected]
Af assist on canon flash 580exii not working
check Custom Functions of Camera and Flash it can be turned off in both locations
Canon flash speedlite 550 ex ttl
2answers
550ex PC sync socket conversions
I do medical/photo equipment repairs & IR conversion, but I'm in the USA.
Over 20 years and Canon knew about that problem including many photographers. Most of Canon flashes can not do manual or aperture mode because they have to flash sensor.
Now they have it on the 580EXII. I guess Canon has no photographer working in the flash department.
Canon screwed photographers, buy a Metz, Vivitar, Sigma, Sunpak, or NIkon.
Alexander
[email protected]
1helpful
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
