Dometic 57915531 Air Conditioner Logo
A
Anonymous Posted on Sep 17, 2012
How many watts dose a 15000 btu rv ac use - Dometic 57915531 Air Conditioner
william simpson
Level 3:
Genius:
  • Dometic Master 1,363 Answers
  • Posted on Aug 18, 2015
william simpson
Dometic Master
Level 3:
Genius:
Answers
1363
Questions
14
Helped
317648
Points
1636
Multiply the amps on data plate by voltage applied its watts
2 Related Answers
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
  • Posted on Dec 13, 2010
SOURCE: how many amps will a 15000 btu ac unit pull at
15,000 BTU stating current 18 to 20 amphs. And running amphs will be around 6.5 to 7 amphs.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Aug 20, 2011
SOURCE: I have a dometic rv
For an RV 15000 BTU air conditioner the size being maximum for 115 volts ac you will need to have a independent circuit breaker for it only and rated at 20 amps. The average amps depends on serveral factors like actual supply voltage somtimes 110 to 120 volts and wire size and length feeding the air conditioner. To answer your question the average Amps will be near 13 Amps. Click Here=>
Dometic RV Air Conditioner Installation Manual and Specifications
Click here for a photo of the Electrical Spects.=>
Dometic_RV_Air_Conditioner_Electrical_Specifications
If you have any questions I will be here to answer them for you, Thanks, Sea Breeze
Have a dometic 15000 btu rooftop ac in rv and does not blow cool air r these unit repairable
Yes they are repairable, I would take it to an shop that specializes in RV's and motorhomes.
WILL A TRACE 2000 WAT INVERTER RUN A RV 15000 BTU AIR CONDITIONER
It can but you are not going to do it off a single deep cycle battery, You will need to have some robust batteries to sustain it. But that will almost need to be the only thing on that inverter.
It might be better to spend a little more and get the Air conditioner that can operate on 12 volts or 120 with the flip of a switch.
Look at the data panel for the 15,000 BTU AC. It's current rating should be right around 12 Amps at 120VAC. Which is 1440 Watts. Startup is when there could be a problem. Especially when the compressor approaches a near lockup condition. Current draw can be double that of normal operation Even though it is within the surge rating of the inverter- the batteries have to be at their peak at all times.
WILL A TRACE 2012 INVERTER RUN A 15000 BTU RV AIR CONDITIONER
According to specs, they will take a 44 amp AC power surge. Obviously number and type of batteries as well as battery condition , etc, plugged in, not plugged in to outside hydro, or generator all come in to play here, but a 15,000 BTU roof AC will only draw, 15-17Amps AC when compressor kicking in, ( or less on some new models) and should level out at 12 -13 amp draw after. As well, this will depend on proper wiring to and from main panel as well as AC unit, and incoming voltage, AC unit condition ( cleaned and maintained properly) etc.
How many Watts will 1350 btu RV roof model use? I have a Dometic 641815 model . I want to buy this Yamaha 2400 watt generator.
Hello, I have the same exact generator, 2400 Yamaha. It works fine for my Ac, and then some. After it first kicks on, is the biggest surge. Then I have even after ac is running, I have had tv on and even used microwave. But as far as running you ac on your rv , not problem. I do it all the time. Mine is ulta quite, and 8 to ten hours run time on about a gallon of fuel. Mike
I have a dometic rv unit 15000 btu what is the amp draw?
2helpful
Rooftop RV Air Conditioner: my duotherm rv ac rooftop 15,000 btu the free...
If it's the pencil type, it just pokes into the fins (carefully)
If you look real close with flashlight you should be able to see where it poked in before, usually a couple of inches up from bottom. If it's the little round disc, it snaps in down in bottom corner, there should be a small hole for it in the frame.
I have a 13500 btu ac dometic penguin model on pan that is old and would like to replace with 15000 btu ac of any other manufacturer or another dometic what are my options ..I do not have ducts and do not...
Your choices are another Dometic or a Coleman
I prefer the Coleman But the amount of extra cooling you will get by stepping up to a 15K unit will probability not be worth the added cost
3helpful
Btu for dometic 59516.531
59516 is a Brisk Air 15000 BTU.
Thanks for using Fixya
Jerry
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
