Question about Yamaha EF4500iSE Generator 4500 Watt Inverter Series Trailer Camper RV
Yamaha EF4500Ise Gennerator won't produce power.
I bought a used Yamaha ef4500ise genny for my camper with 80 hrs on it. I put 15 hrs on it, and it worked fine. Now all of a sudden when I turn it on, it's continues to run(good idle) but only produces power for 30 seconds or so, then the overload light comes on. This is with no load on it. I've cleaned the air filters and changed the spark plug and nothing. Someone please give me some good news(easy fix). It'll **** that i just gave $1500 for this genny for 15 hrs of use. Thank you in advance.
  • jerosan77 Sep 20, 2012
    It was a bent pin. It had a recall for the carburator, when it was replaced, the dealer bent some of the pins that connected to the idle. Therefore it was running high idle(pushing 300amps) and overloaded immediately. The pins were replaced and everything works better than it did originally. I'm thinking the guy that sold it to me thought it was toast and tryed to screw me, little did he know, it was covered by warranty still and didn't cost me a penny. Yamaha is good to go.
    New Friend:
Doe's it have a thermal couple on it? If so it could be bad and when it heats up it is killing your power.
Posted on Sep 18, 2012
  • jerosan77 Sep 18, 2012
    The AC power goes out immediately within 30 seconds or so
SOURCE:
How to check the stator on the early 90s yz80
Hi, Scott for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere $15 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Electrical guru help please with early 90 yz80
beg for your help yz 80 no spark
Yamaha YZ80 service manual repair 2001 YZ 80 YZ80LW Download Manuals... $15
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 25, 2017 | Yamaha Motorcycles
1980 Yamaha GT 80 wiring diagram
Hi, Jason for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere $15 you can download another one.
1980 Yamaha GT 80 wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
DOWNLOAD NOW Yamaha GT80 DT100 GT 80 DT 100 77 82 Service Repair Workshop... $15
https://www.partsfish.com/page/oem-parts-for-yamaha
http://mybikemanuals.com/yamaha/yamaha-mx-owners-manuals
Oct 29, 2014 | Yamaha Motorcycles
Is it possible to change a ef4500ise from a bonded neutral to a floating neutral
Unless you are going to use this exclusevly for 240V service, this is a bad idea. Your 120V legs will float between 0V and 220V.
Dec 18, 2013 | Yamaha Electrical Supplies
Goes into overload and shuts down
Not very much information in your problem troy but you might be drawing more amps than your producing. I had bought a nice little Craftsman electric tire pump but my Yamaha kept dying. After reading the labels, my 2400IS puts out 15 amps and my tire pump needed 18 amps, my friend now has a nice tire pump for his home use. I've seen post that RVers have to add the "booster" kit to start their air conditioners, extra power is needed to start them after that the 2400 can run them. Just a thought, try reading the metal tag on what your trying to run and see how many amps it needs. Anything over 15 will shut you down and some will need that extra "boost" to get them started. I seem to think I read somewhere that it is about $75.00 for the Yamaha booster kit.
Aug 12, 2013 | Yamaha EF2400iS Portable Generator
Yamaha xl 800 won't hit top speed and won't rev out to max rpm
Did the Impeller Pitch Change? Pitch will change the Max RPM, Are you Pulling harder out of the Hole than you did prior? You may have traded Torque for Top End
Apr 02, 2013 | Yamaha Xl Xlt 1200 Gp1200 800 Limited Air...
What type of oil does a 1980 Yamaha GT80 use
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $15 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1980 Yamaha GT 80 fluid basics
http://64.234.201.42/YamahaSnitz/topic.asp?TOPIC_ID=476
Jun 13, 2012 | Yamaha Motorcycles
Correct spark plug for 1999 yamaha yz 80
Spark Plug Search Results
http://www.transcanimports.com/downloads/Motorcycle%20&%20ATV%20Catalogue/Electrical%20-%20Spark%20Plugs%20-%20Yamaha.pdf
DOWNLOAD NOW Yamaha YZ80 YZ 80 1999 99 Service Repair Workshop Manual... $15
Jun 03, 2012 | Yamaha Motorcycles
How much oil do i put in 1990 yz 80 front forks
Fork Oil Quantities
YZ 80 fork oil amount
DOWNLOAD NOW Yamaha YZ80 YZ 80 1990 90 Service Repair Workshop Manual... $15
May 13, 2012 | Yamaha Motorcycles
10 months ago I had my 6 year old Dometic A/C replaced by a friend who bought the new unit directly from Dometic via a Dometic employee. It worked fine the two times I use it this past winter while...
10 months ago? Do have any warranty on this?
As far as adding refrigerant. Yes - you can add some - but you need to fix the leak first, since it will be quite expensive to keep putting refrigerant in. I would first try to get the mfc repair it and if that fails I would call a serviceperson.
note: fixing a leak and re-charging the system is going to take someone 'very' knowledgable of air conditioners.
good luck!
Jun 13, 2011 | Dometic Rooftop RV Air Conditioner
I am building an off grid cabin but will need to meet code providing all electrical components as per the latest NEC. I will be using a 4100 watt generator for my initial power source but plan on...
I think he cost of the panel and breakers would be the cheapest thing on your list. Your 4100 watt genny is tiny for a whole house, and if you are planning on a solar set up, you will need to convert to dc, so, I take it your 4100 genny is used to charge the battery bank? Then the panel will not need to be anything but a small disconnect for the genny, basically one of those things that prevents the current from flowing back into the source, which you don't have. I would talk to the building dept., they may not want to take liability, and make you get a contractor to figure something out. All your appliances, and lights will be 12 volt, most motors are 12 volt anyway, they are just transformed to 12 volt from 110 current, and I don't think you will need breakers for 12 volt stuff. You could look at some camper supplies, boat stuff, they all run 12 volt appliances, and lights.
Feb 12, 2010 | Your One Source Homeline Load Center, 200...
Yamaha EF4500iSE Generator 4500 Watt Inverter Series Trailer Camper RV Logo
333 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
John Trevino
Robert Wooley
Robert Wooley
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
