SOURCE: satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
SOURCE: have dish receiver 510, channels i need are on
Donna,
I am sorry to hear of your troubles. I am assuming you have another receiver in the house that is an HD receiver as the 510 is not and it would not make any sense for you to have the 129 orbital without it. If you go to the other receiver and are able to get transponder 21 on the 129 bird then the issue lies in either the cabling, connectors, barrels and or wall plate, or the 510 itself. Assuming you were good to go with the hi def receiver move it to the 510 location and see if you are able to still p/u the 21 transponder. If so, the 510 is bad and needs to be replaced. If not the problem lies in the aforementioned areas. if yoou are unable to get the 21 transponder on the hi def receiver also then more than likely the dish needs to be repeaked. If I can be of more assistance let me know. Thanks for using Fix Ya.
SOURCE: added a 322 reciever to
Is TV 2 off the 322 receiver being back fed from the receiver or do you have a direct connection to the 3rd room? If it is a direct connection, you would screw the coax from the 3rd bedroom directly to the TV 2 Home Distribution channel 21-69 out port.
If you are back feeding, you need 2 diplexers that connect 1) by the receiver and 2) between the receiver and the 3rd TV. The back feeding will use the same cable coming from the dish to the receiver.
If you have any other questions, please don't hesitate to ask.
