Sony Ericsson Sony Xperia S Lt 26i 32gb 4.3" 1.5 Ghz 12 Mp Black Android 2.3 Factory Unloc Logo
Michelle Alias Posted on Sep 17, 2012
My phone got wet with water what can i do to fix it? I have the new sony erisson xperia LT26i the battery is built in
The phone fell in the tolilet and got got wet i dried it intantly with blow dyer i want to turn it of because i was not off automatically but it shut down on its own.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 18, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
296
Points
Make sure all the water have dried up before putting it on put it in the sun for a day then try putting it on
5 Related Answers
A
Anonymous
  • Posted on Jul 09, 2008
SOURCE: 580i shut off and will not turn on
Try to push down on the battery when you try to use it.
Anonymous
  • Posted on Aug 14, 2008
my sony ericsson wet not working
Anonymous
  • 182 Answers
  • Posted on Oct 18, 2009
SOURCE: how can i increase sms memory on my phone, though
YOU CANNOT INCRESSE THE PHONE MEMORY IT WILL BE FIXED THAT PHONE MEMORY IS SHARED IN SONY ERRICION THAT LITTLE MEEMORY TO SAVE CONTACTS AND LITLE MEMORY TO SAVE MESSEGES AND OTER APPLICATIONS ETC IF YOU NEED TO INCRESES PHONE MEMORY THEN REMOVE THE CONTENTS FRON CONTACTS ,APPLICATIONS ETC... THEN YOU CAN USE THE FULL MEMORY FOR SMS
Anonymous
  • 33 Answers
  • Posted on Jun 12, 2011
SOURCE: got my sony ericson xperia
hi sorry to inform you but you need a new screen the wetness stop the lights in the screen to stop working. check any cell phone *** Put some style on your phone. Accessories as low as $5. stores.ebay.com/Clothes-4-Phones
Anonymous
  • 223 Answers
  • Posted on Jun 13, 2011
SOURCE: phone fell down in toilet.
If your phone fell from a long height it may have effect your mobile mic.So go to your nearest service center for changing your mobile.If you doesn't no the service center you can contact the customer care for nowing the address.They may charge you for changing the mic.If your phone as warranty also they will charge for water problem they will not cover. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
What can i do to get my phone working again?
Probably too late if it was powered whilst still wet. Next time you drop a phone in water, quickly take the battery out and place the phone in a bag of rice for at least 2 days. The rice gradually absorbs all the moisture. Never use a hair dryer because it blows water molecules into the display panel and other delicate parts.
How do u unlock password on a sony xperia lt26i
Do you want unlock sony xperia lt26i mobile network lock password? You can visit this site Unlocking4u.com here you can get the unlock code and unlock your cell phone. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email.
http://www.unlocking4u.com/sony-ericsson-lt26i/rs6wp9/
May 30, 2014 • Cell Phones
2helpful
3answers
How to nulock sony xperia s lt26i
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA S smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
  6. The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA S battery is charge properly or full charge
  4. Power off SONY XPERIA S
  5. Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA S
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
Proximity sensor not working in sony lt26i
que puedo hacer para acceder a donde puedo desactivar el sensor de proximida [email protected]
Xperia s LT26i sim network unlock pin
To get Sim Network Unlock Pin for Sony Ericsson LT26I model phone visit the site Onlinegsmunlock.com
after getting the network unlock pin you can unlock it easily.
2answers
Yellow tint
How to remove password sony xperia LT26i
Fell my xperia s in salt water
This happened to my phone once, I just took it apart (the bits I could, sim card, battery, cover etc) then dried it for quite some time with a hairdrier (on a cool setting) then left it over night apart. Put it back together in the morning and it worked. I'm guessing there was still water/ moisture inside of it to stop it working..
1helpful
3answers
Security code forgotten...sony xperia lt26i how to crack it or erase security question?
i have forgot the email and passwords, i forgot the pattern lock and also i do not remember the security question. How do i Ultimately unlock the phone and turn the lock off?? do i have to do a format or hard reset to clear off the passwords? - how do i do that??
3helpful
Need sony ericsson xperia LT26i pc suit
i want to update my system so i required pc suit
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
