Question about Canon MultiPASS MP730 All-In-One InkJet Printer
MP730 "wrong cartridge" error
I had this error show up and I replaced ink cartridges. The message remained on my printer. I cleaned printer head and still have the same problem. I am considering buying a printer head but worry that I the machine may not work due to not being able to "RESET" my printer.
Any ideas before I make another purchase?
Well...
I can tell you what I did.
I came up with this "wrong cartridge" problem today, searched around the web -- there are a number of ideas -- and then started off on my own.
Perspective: I bought this MP730 in 2003 and have been filling the same set of ink tanks since then. Never had a problem with that. Don't know offhand how many pages I've printed, but I refill the ink every couple of months.
What I did...
I removed the ink tanks and the print head. The print head area was all gunked up with ink as well as the flanges the print head sits on (still in the printer). I DID NOT dunk the print head in water. Something in me says water and electronics is not a good thing. The refill ink package I buy comes with printhead and cartridge cleaner -- smells like alcohol, but who knows. I used that and a combination of Q-tips and kleenex to clean any ink away from the print head and nearby surfaces. I also dripped some cleaner into the print head holes the ink tanks plug into and then dried off the whole print head assembly. I purposely did nothing else. That way, I'd know if I'd found the solution.
I put everything back together and fired it up. The printer cycled itself, removed the "wrong cartridge" message and stood ready for me to print. Finished, right??? Not so fast.
I printed out a Windows test page.....it was totally blank!!! Pause....printed out 2 more.... blank... Uh-Oh.
So, I lifted the lid on the printer, lifted the print head lever, jostled the print head a little to ensure good contact, put everything back together and printed another Windows test page....PERFECT!!!
Note: some writers mentioned cleaning a switch off to the right in the printer. I looked at that area and it IS pretty gunked up. But I didn't touch it to clean it up. That way I had a better idea of what DID fix it. I left it gunked. Of course, maybe all I really had to do was wiggled the print head and put it back together. But at least my print head is clean now. ;-)
So, that's all I did. Don't know if it wil help you, but it's a start.
Posted on Dec 29, 2008
I had the same «wrong cartridge» problem and could get it solved. Here is what i did? Following the first instructions from DallasSmith, (1) I put the cartridges-leaver up and removed the 4 ink-cartridges; (2) removed the print-head which is not screwd or hard-attached so all you have to do is carefully take it out of its place (I suggest directing a strong light to this area to understand the parts beeing touching); (3) once outside, the print-head had no ink on the black-cartridge touching area which i believe due to a problem in the black-ink cartridge, since all the other 3 contact areas had a good amount of ink. I assumed that the black-cartridge was not delivering ink which leads to the machine error and forced by hand some black-ink to this area and replacing the black-cartrige by a new one. It solved the error. Additionally, I did also the cleaning of the head. No water, just a kleenex with one or two drops of alchool. In the end, i believe that this was really a problem with one cartridge which the printer could not take ink from. Consider also that this solution may apply to any of the other color ink-cartriges. In conclusion, check the status of the ink-interface between all the cartridges and their socket. If some is too clean, suspect of that cartridge.
Posted on May 14, 2009
SOURCE:
Wrong cartridge...I removed the cartridge head, cleaned with alcohol as suggested, to no avail
If you are getting an error that says "wrong cartridge" then the ink cartridge you are trying to use is defective. Return the cartridge to the store you bought it at and get another one. Do not use refilled cartridges unless they are purchased by a professional who knows what they are doing. Your problem lies with your ink cartridge and not the printer.
Jul 16, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
I keep getting a "wrong
Clean the print head/cartridge with Isopropol Alcohol (rubbing alcohol)and Q-Tips, The nozzles, the contacts and all the excess ink that had acummulated around the nozzles. The error message should clear.Run through all the maintenance checks and alignments. If this does not fix it, the print head needs to be replaced about $45-$60 from Canon.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 20, 2011 | Canon SmartBase MP730 All-In-One InkJet...
I have a canon mp730 and since I have replaced my ink cartriges I keep geting a wrong cartridge message. I have checked and rechecked installation and re booted several times to no avail. I have checked...
Many times , if we use refilled ink cartridge , then also we might get such error messages on the printer display .
Ensure that you are using genuine Canon ink cartridges.. but if the error is after changing to a new set of genuine ink cartridges..
try by cleaning the electrical contacts of both ink cartridge and the printer.. and also do a semi full reset..
Aug 12, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Re cannon mp730 all in one -I keep getting ?wrong cartridge? error msg. when I followed the solutions that had been posted a month or two ago, removing the cartridge holder, etc. I found that the ink was...
Your print head may be damaged. You might consider replacing it.
Canon suggests pulling the ink wells and also pulling the print head and then reinstalling the whole assembly. They consider this a reset. It is also suggested to replace the printhead which the ink cartridges are housed in. I have done this to remedy bad printing and am considering this $50 purchase as I am dealing with "wrong cartridge" message also. Some have said replacing the printhead remedied this code problem. BUT, i did read one person who said this did NOT work. Right now I am debating whether I should put $50 dollars more into this machine....although this printer has been excellent and many agree.
Comments: Apr 17, 2010 - As a follow up I did fix my "Wrong Cartridge" message by replacing the printhead, I worked and worked at cleaning the old one but finally gave in and anted up the $50. This fixed it! Long live DIYers!
Apr 09, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
I have a Canon MulitPass MP730. Wrong Cartridge message.
It's worth repairing, That error on a Canon is saying that the printhead is bad, not your cartridges. The part number for your printhead is stamped on the side of the printhead could be QY6-0049-000 but I'm not sure.
Jan 10, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Lcd message "wrong cartridge". I rebooted, replaced an ink cartridge, reseated the print head. What's left?
The wrong cartridge error happens when the printhead goes bad. The only thing to do is replace the printhead.It is QY6-0064-000 for around $40.00
Jun 30, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Mp730 message wrong cartridge??? I did install a new ink cartridge, no help so I cleaned and reinstalled the print head after shutting it down for 30 mininutes no help. Still geting the same message....
That message means that you need a new printhead, the holder where your inks go. the part number is QY6-0064-000 around $40.00. easy to change yourself, instructions are included.
Jun 29, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Weong cartridge error on my LCD screen--I cleaned
Wrong cartridge error is a problem with the printhead, needs to be replaced. Qy6-0064-000, aprox. $40.00
Jun 22, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Wrong cartridge
I have the multipass mp700 and have just experienced the same message ..... wrong cartridge. After reading the manual, from the disc, it means that there's something wrong with the print head, most likely needs cleaning, but it won't clean because the printer is sending a malfunction message. I will be trying to clean the head and if that doesn't fix it then I'll buy a new print head. Good luck with the problem.
Aug 15, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Display Says Wrong Cartridge
I went to the Canon website http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9035 and typed "Wrong Cartridge" in the search portion for the MP730. It listed detailed instructions to remove all ink cartridges, raise the lever to the right on the carrier, and then remove / reseat the "carrier". After that I replaced all cartridges and printed the alignment page. All is working, now.
May 11, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
3,684 people viewed this question
Clive
Clive
old marine
old marine
