How can i clean between the glass on oven doors. unslightly streaks have appeared. I have a drip mark between the double glass window on the door. Don't know how it got there. The stove is only 2 yrs. old.
Thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
I found the solution! Take out the broiler pan. Lay on the floor on your back and you should see two long openings along the width of the door. I made a solution of 1/2 c. isopropyl alcohol, 1/2 c. while vinegar and 2 c. warm water. Wet a kitchen towell with solution, pin the towell to a metal hanger, (pulled out from hook to the center bottom wire) so the hanger was double width. This makes it sturdy. Flip the rag with wet solution over the hanger, and insert in the openings on the bottom, clean by rubbing against the glass where soil is, then remove. Do the same with a dry kitchen towell so there are no streaks! I guarantee when your on the floor you might notice alot of areas you don't normally clean, I did! the solution also makes the best window wash solution.
How?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
drip marks between glasses
I would love to hear how to clean this out as well...
I have drip marks and spots between the double glass window on the door. Don't know how it got there. I would like to know if there is a way to take the door apart to clean between the double glass
i have the same problem. i am going online to try to find a solution. i am going to call frigidare to see what they tell me.
