Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
Posted on Sep 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i get a 21dv50 water heater to buy
40000 BTU, 50 GAL, Natural gas
Gene Haynes
Level 3:
  • Rheem Master 5,391 Answers
  • Posted on Sep 17, 2012
Gene Haynes
Rheem Master
Level 3:
Answers
5391
Questions
0
Helped
2606332
Points
14124
21dv50 is discontinued. This is ordinary tank-type 50 gallon gas water heater.
Amazon sells 50 gallon 22V50F1 Rheem water heater for $420 with free shipping ... but who carries the warranty?
Frankly you can get in-store returns, and buy same quality gas water heater at local box store since Rheem makes GE water heaters at home Depot.
Other brands are equally good, as AO Smith makes Kenmore water heaters at Sears and Whirlpool at Lowes.
I prefer the AO Smith because maintenance is easier.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5 Related Answers
t1m130
t1m130
  • 86 Answers
  • Posted on Mar 15, 2009
SOURCE: Elec water heater
first turn the breaker off there should be two covers on the font of the heater if you r just looking for adjustments u can take those covers off and there is usually a foam piece behind the covers pull the foam off and there should be a dial to adjust it
Anonymous
  • 234 Answers
  • Posted on Mar 17, 2009
SOURCE: losing hot water in one facet only
There is something in the line or in the faucet.Are your pipes going to the faucet black iron or galvinze.Some of the pipe will rust up and stop a full flow of water.But I would check the faucet first to see if the screw is loose or somethng in it.
Anonymous
  • 949 Answers
  • Posted on Apr 14, 2009
SOURCE: No Hot Water in morning
Remove the cover then the access cover, then you can see inside,
the pilot light is probably out.
If out turn the gas off, then get a long match, grill lighter,or piece of paper ready to light, you should be able to see the little thin
gas line that runs inside the tank and see where it connects to,that is where you need to light, now that you see where to light, turn gas knob to pilot, and press down and at the same time light the pilot.
( blow into the pilot area before putting match inside to make sure no gas has built up inside) Hold down the knob for a minute then release, if pilot goes out try again and hold down longer, if you hold it for 3mins and it does not stay lite, the thermocouple is bad and you will have to replace it.
David Jewell
  • 454 Answers
  • Posted on Feb 23, 2010
SOURCE: I have a Rheem 50 gal. natural gas water heater
The most common reason a pilot light will not stay lit is a bad thermocouple. How old is the water heater? If the pilot light will light, but then go out when you release the safety button, that is a sure sign the thermocouple is bad. You can buy a replacement thermocouple at your local home improvement store. There is a small chance that the control valve has gone bad, but that is highly unlikely.
vincob
vince janis
  • 718 Answers
  • Posted on Jul 25, 2010
SOURCE: I have a Model 41V50 Rheem water heater (50 gal.
You don't need to find the same exact model to replace your water heater, any 50 gallon water heater will do unless you have a brand specification that you like to stick with.
Hot water heater
You need to change the elements out
1helpful
Btu rating on natural gas meter
Gas meters are usually rated in cubic feet per minute (CFM) not BTU. there are 1027 BTU per cubic foot so do the math. Try the link below Btu rating on natural gas meter
2helpful
I have a Model 41V50 Rheem water heater (50 gal. natural gas) and needs to be replaced. However, I can't find this model at any of the local stores. Has this been discontinued? If so, what can I get for a...
3helpful
I have a Rheem 50 gal. natural gas water heater mod#21V50-6A followed all instruction and can't get pilot light to stay lit.
Caluclation
This requires a little math....
BTU - amount of heat it takes to raise one pound of water 1 degree F.
I gallon of water = about 8.54 pounds
91 gallons of water = about 777 pounds = 777 pounds x 70 degree rise = 54,390 BTU.
1 Therm (what the gas company measuers in) is 100,000 btus
1 therm costs about $.45 (45 cents) depending on where you are
54,390/100,000 x $.45 = about $.25 per hour
This cost can vary somewhat depending on the inlet water temperature, gas cost, and the efficiency of the hot water heater
Losing hot water in one facet only
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
