After you put the wrong pattewrn in about 3 or so times at the bottom of your screen you will see a forgot my pattern option. Click it and then sign in with your google account.
If you try a lot of times and lock yourself out, try going back again before the timer finishes and you should be able to see an option that says "forgot pattern?"
If you've forgotten your screen lock pattern, you have up to five attempts to try and unlock HTC Wildfire S. If this fails, you can unlock HTC Wildfire S by entering your Google Account user name and password.
On the unlock screen, enter your lock pattern.
After the fifth attempt, when you're asked to wait for 30 seconds, tap OK.
If the display goes off, press the POWER button to turn the display back on, and then unlock the screen.
Tap the Forgot pattern? button when it appears.
Enter your Google Account name and password, and then tap Sign in. You'll then be asked to create a new screen lock pattern. If you no longer want to do so, tap Cancel.
After you put the pattern in a few times incorrectly it will lock the phone and an option at the bottom will appear that says "Forgot Pattern?" Select that and enter your email and password to unlock the phone.
It says Emergency Calls means it locked to Network Lock,You need to Unlock it from Network Lock,You can get the Unlock code at http://www.mobileunlocksolutions.com/htc-touch-hd/rs1wp9/ and Unlock it,Then You can get the password code from service provider as free of cost,.
If you keep entering the wrong pattern eventually it will ask you to sign into your google account and then you will be able to choose another pattern.
Your IMEI numbers are needed to unlock your HTC G1 mobile phone. Reveal the codes by pressing *#06# on your phone keypad. Then after getting the information, please go to an HTC UNLOCK CODE website for you to be provided with the correct codes. You also may need to know the country and network the phone was purchased from. thanjs
IDK about a simple legitimate fix for this. I was just messin around with the pattern, hit "forgot pattern" to see what it does. It asks me for the Google username and password, but has no way for me to go back! I know the pattern! The Motorola Droid is free from this problem, when on the forgot password screen, it still allows me to go back to the pattern screen. Very disappointing HTC...
On the other hand, there is a bit of a "hack" that can be used to solve this. Create a new Google account. Then call the locked phone from another phone. While in the call, you have full access to the phone. Press home, go into your settings, and add your new Gmail account into the phone. End the call, go back, and enter your new Gmail info. You may also need to enable Wifi while the call is still connected, I'm not sure if 3G will work for the sync while the phone is "locked".
