It isn't the remote, as I've removed the batteries. Also, the TV/video button on the front of the TV its self doesn't seem to be stuck or malfunctioning. Any ideas?
You have to replace all the micro-switches at its front panel switch board PWB.
Send your email address to me by Fixya comment. I'll send a copy of its repair manual to you. It have all details with illustrations. If you have an idea in electronics, you can do this work. The manual will guide you more with illustrations.
Check this link and select the site named 'Electro-help' and see whether it can help you or not.https://www.google.co.in/#hl=en&scli...
SOURCE: reddish screen on sony wega kv-28fx68 100hz trinitron
it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting.
SOURCE: Sony KV-27FV310
Component In is not converted to composite out (yellow)
TV monitor out normally goes to A / V receiver in......T.
SOURCE: Sony 36' TV Volume Goes up on own/Stuck on Video 2
Hi -
I had the exact same problem recently with my SONY Trinitron 27 inch TV! After trying everything, I found that pushing the Up and Down volume controls on the TV panel (ie NOT on the remote) at the same time, the problem went away. I hope that this helps!
SOURCE: Sony KV-32HS420 will not come on has blinking standby light
Get out your original remote and hold the "Setup" button at the same time as holding the On/Off button on the TV set. It just worked for me!! Thank goodness. I was just about to bring it for repair but there's a snowstorm. Here's the link I got this from: http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=http--esupportsonycom-perl-tutorial-displaypltutid297templateid1regionid1KSMFlag7370&sliceId=&docTypeID=DT_TUTORIALS_1_1&dialogID=53101564&stateId=0%200%2053105132
SOURCE: how to turn standby off
The TV circuit may have detected a problem within its parts. You may have to check some leaking capacitors in the board or loose solders or burned components just to make sure. Normally leaving the TV unplugged overnight should reset it.
i was afraid of that. can you tell me how to get the front panel off the tv to access it? i couldnt see an easy way to do so.
my email address is [email protected] Thank you so much for all your help.
