Audiovox JENSEN IPOD DIGITAL DOCKING SYSTEM (077283991912) Docking Station Logo
Posted on Dec 26, 2008
My Jensen ipod docking system wont charge my i touch
My Jensen Ipod docking system will play my i touch ipod but wont charge it?
  • perfectpal Mar 08, 2009
    same. i have an itouch and an ihome and they both work fine, but it wont charge my itouch while its on the ihome. i have to plug it into my laptop instead. is there anyway i can get my ihome to charge my itouch? i hate turning on my laptop to charge it.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1098
Points
The older ipods charge using 12v, the newer ones (including the Touch 2nd gen) use 5v. So a lot of docks that will charge a nano will not charge a new Touch. If a dock says it will work with the iPhone then it will work with the newer iPod Touch (2nd gen).
If you have an old dock and want to charge a new Touch (sounds like the case here) then you can get an adapter. Scosche makes one just for this.
Anonymous
Level 1:
New Friend:
  • Posted on Nov 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1098
Points
You may need to switch the piece you charge it on. That happened to my JBL i just changed the piece and it charged the ipod
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Dec 26, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
2985
Points
35
If you charged you thing for to long it will mess up the battery so you need a new battery
Jensen jiss-115 ipod touch doesn't work
It will cost you less just to get a different one (Shilia) then to have it repaired,
2helpful
My ipod wont play through the docking system, how do i solve this? it is a sony ICF-CS10iP. i have tried unpluging it. it used to work when i had this problem before. but it hasnt worked for a couple days...
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These model Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be re-soldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Can not get a iPod touch to charge. Is this iPod supported. Please help.
There is a fix for this. Unfortunately, the some ipods will function properly with the exception of charging. You can buy an adapter to fix this. You can find them on ebay. Go to ebay and do a search for "Scosche charging dock adapter" The adapter plugs into your charging dock and then the ipod plugs into it. They usually come in black or white. If you get the same color as your docking unit you wont even see it once its installed. This works...I have one : )
Ipod charges on bose dock but won't play ipod firmware 3.1.2 recently updated
i have bought a ipod nano and i want it to work in my car stereo it charges but does not play it does play my sons ipod touch so the cable is ok
The Radio recognizes my 3G I phone and charges it when i place it in the dock, but it takes several attempts to ge the i phone to play through the radio. I can't get it to play through the radio until i...
If possible, please post the model number of your Jensen HD radio. The Jensen HD radio that I know about is only meant to support the iPod nano, iPod with video (5.5G), original iPod and iPod mini.
Wont play out of docking speakers
Hi
My iPod does the same it does not play out certain speakers.
Take back the speakers.
Take back the ipod.
Go to:http://www.apple.com/support/
Tom
Wont play through my bose system anymore
the apple ipod are very delicate and it seems that docks are very harsh on the internal workings IE: motherboard of the ipod. it not just the touch, it's all ipods.
My suggestion is to check the headphone jack and if you get sound, don;t play your ipod on the dock at all. Your dock has probably done some damage to the audio circuit on the board.
If you get sound through the headphone jack save your ipods life and just use it through the jack.
I have replaced numerous motherboards on ipods played on docks. they just don;t handle the charging and playing very well whether it's heat or just the wrong voltage I am not sure.
But my first question to a customer is have you played it on a dock.
I would stay away from the dock
Inmotion speeker dock wont charge new ipod touch
This is because you are using different generations.
If the dock was only meant for 1st generation, then itwill only charge 1st generation. It's how they make their money.
Ipod cuts out when played through speaker system
i have somewhat of a similar problem with my ipod Touch and my JBL docking station alarm clock thingy. It may just be that the ipod is not compatible on some of the levels that the Igroove is. With my docking station, it wont charge my ipod touch itll only play music
2answers
Itouch charging
Some speaker systems which are only compatible for charging the ipod nanos and classics do not work with the iPod Touch and the iPhone, the internals are slighly different from one another which will not allow that speaker system to charge your iTouch.
To play & Charge your touch, i suggest getting a speaker system that supports the iPod touch platform.
Hope this helps ?!
Top Audiovox Audio Players & Recorders Experts
John
John
ADMIN Andrew
ADMIN Andrew
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
