ROLLER LINES AFTER PRINTING PHOTO 8X10. OLD PAPER OR PRINTER PROBLEM?
SOURCE: Hp 7550 ink jet printer printing uneven
My first guess is that it is a cartridge issue, due to these printers having the print head as part of the cartridge, there is nothing else, it makes the whole cartridge the only printing item. Ensure the carts are not old (exp date) and that they are HP, With that all understood as I now see that you must due to owning it for 6 years, then you could try to clean the contacts on machine's "cartridge holder" and give that a clean too while your at it cause it may be the problem here (see below)
If a inkjet printer lasts 3 years you would be doing well, and you've had 6. Exceptional!
HP Photosmart printers may print images with white lines or single color streaks. This issue can be caused by ink that has dried in the ink nozzles or by debris that is blocking the ink nozzles. The ink cartridges and the and printer cradle should be cleaned. Clean the ink cartridges with the ink cartridge cleaning utility in the HP Printer Toolbox. Also, clean the ink cartridges and the print cradle manually.
Cleaning the ink cartridge cradle
Manually cleaning the ink cartridges
Cleaning the ink cartridges with the HP Printer Toolbox
If you've got this far then I should tell you that these days, Printers aren't worth fixing, one just replaces them with new
SOURCE: Problem printing with HP Business inkjet 1200 1-800-532-4187 IS SPAM
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
SOURCE: HP 5510 All In One. Error message Paper Jam when
Have you changed the paper properties to reflect that you are using a heavier weight paper?
If not, then the printer might not be set right for the paper you are using and that can cause the problem you are seeing.
SOURCE: How to unjam a paper
Depending where the jam is you need to follow the appropriate solution. There's also a video on HP support website on how to clear a paper jam out of your HP Officejet 6500A Plus printer: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02441153&tmp_task=solveCategory&lc=en&dlc=en&cc=au&lang=en&product=4083977
SOURCE: Cannot print on regular letter size paper on my HP
I had same problem. Try this: When you go to print, change your ink quality to "draft". For some reason, I was able to print after trying everything. Hope this works for you!
