Hi
Connections to the computer is usually done via USB cable. Turn off your PC and connect the cable, then start both devices. Check the drivers for probable updates from the product's support site. If installing the printer drivers for the first time, make sure you connect the Usb cable only after the on-screen instructions prompt you to.
Download a complete guide on set up from the link below.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=441125&
Hope it helps.Thanks.
The camera device is likely disconnected from computer port. Attempt to establish connection cables by unplugging and reconnecting several times to allow the computer to recognize the activity. The sensitivity of the computer with device would simply recognize a reconnect. Usually, the computer has to be restarted to acquire the connection capacity with prior computers and peripheral devices.
