Tablets & eReaders Logo
Posted on Sep 16, 2012
Tablets wont boot up just shows arnova on screen and shuts down
  • rico8star Sep 18, 2012
    archos arnova 7g2 wont start. it shows arnova on the screen and switches off after 3-4 seconds
vhinz
Level 1:
  • Contributor 1 Answer
  • Posted on May 18, 2014
vhinz
Contributor
Level 1:
Answers
Questions
0
Helped
7088
Points
0
Arnova 7 g2 has no volume button..
Julie bickerstaffe
Level 1:
  • Posted on Feb 05, 2015
Julie bickerstaffe
Contributor
Level 1:
Answers
Questions
0
Helped
7088
Points
0
My son's tablet won't turn on
Leigh Tony
Level 1:
  • Posted on Apr 20, 2014
Leigh Tony
Contributor
Level 1:
Answers
Questions
0
Helped
7088
Points
0
What if you getting a yellow android robot, oppose to a green one, and all you can do is to whatch the tablet restarts but no reboot . How can i slove this problem?
3 Related Answers
spshort
EasyPC123
  • 36 Answers
  • Posted on Jan 15, 2014
SOURCE: supersonic 7" touch screen MID Tablet
You need to flash new firmware you can download LiveSuit and
then look for the correct firmware that is compatible with your tablet.
If you search for How to Flash Tablet there will be a video or instruction on how to do it.
TechyDrood
Justin
  • 2072 Answers
  • Posted on Oct 16, 2011
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Anonymous
  • Posted on Oct 07, 2012
SOURCE: my tablet is froze it wont shut down it wont powder off
Get a toothpick and hit the reset button on the back or side
I've followed your instructions on shutting down my tablet and trying to unlock the lock icon with no avail. What next?
If you tried sliding the lock icon and it doesnt move in any direction, chances are that the tablet is frozen. In that case, hold the on/off button for about 5 secs or until the tablet turns off (it will vibrate as it turns off, this is different than just pressing the on/off button) or offers you an option to shut it down. Wait a couple of secs, the tablet will show the booting screen and then allow you to work with it, not just showing you the lock as soon as you turn it on. If it shows you the lock without the booting screen shown first, this means that you didn't really turn it off properly. Try holding the on/off button longer!!
The lap top will not switch on
Power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button.
select Reboot Tablet Normally.
Archos arnova refurbished 7k G3 tablet frozen on ARNOVA screen
i had same problem with my gadget,i replaced the battery.and have it checked to make sure no reformattingg needed
Arnova 7b G2 touch screen doesnt work
i have same problem here and i didn't find any solution yet still search and wait ..
How to put arnova 7 g3 in recovery mode
make sure the tablet is off, then push and hold the reset button(small hole on same side as power button), while holding the reset down push and hold the power button. continue holding both buttons until you see the "Arnova" flash screen, then release the two buttons. this should put you in recovery/download mode... it is not touch enabled though, and there are no physical buttons on the tablet, so you will most likely need the Rockchip flashing tool. Good luck
1helpful
Archos 10g2 wont load up
Just flash the default firmware from the manufacturer:
http://arnovatech.com/support/firmware/2/arnova10g2/111010/update.img
http://arnovatech.com/support/updates.html?country=us&lang=en&p=2
Flashing a firmware means installing it in the device protected flash memory, more explanations here: http://www.addictivetips.com/mobile/what-is-meant-by-firmware-stock-custom-roms-and-flashing-guide/
The firmware flashing procedure for your device is detailed on Arnova web site:
http://arnovatech.com/support/firmware.html?country=us&lang=en&g=2
6helpful
3answers
Brand new archos arnova 10 tablet. It is stuck on the charging screen. Won't turn on or off. Have hit the reset button. Didn't help, continues the same problem?
1helpful
2answers
I have error on my tabletit saying it has to close and wont let me do anything
sounds like your explorer is not working properly like its been hacked or got a virus where you jave visited a web site and not paid or something or bought their antivirus and now its shut you down so its a complete re-boot to clear the high key registry
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
