SOURCE: MEMORY CARD PROBLEM in NOKIA
Memory
card is not working in my nokia 2730 classic device, even if i insert
other mem.card which is working in other phones, the memory card option
is not seen in my nokia 2730c device.Can any 1 assist me to fix this
problem??!!!!.
Thank you.
SOURCE: how to unlock mmc card password for nokia 6230i..
Hi!
You can use a portable decoder for your memory card to have it unlock.
You can buy it here:
Please click the link: www.Alibaba.com
This will direct you to the device page.
I hope it helps..
Thank you for reaching Fixya.
SOURCE: my 2GB sd memory card
you should put your memory card in nokia s60v3 phone, like n78,n81,n82, etc. And then, unlock your memory card with standard code like 1234 or 12345. try it....
SOURCE: i'm using Nokia 2730 classic.
hi ,
go here to fix your problem ...http://www.fixya.com/support/r8203176-unlock_removed_password_in_memory_card
i hope it will help you ,thanks for trusting fixya..and if you find this helpul ,leave your comment
SOURCE: my mobile model no is
Hello Arefin,
To Remove the memory card password from Nokia 2730 Cell Phone :
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file.
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
"IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T
FORGET
TO RATE ME"....THANK
