Question about Leviton 1755 Triple Rocker Switch Decora
Installing Levitron 1755-T three rocker switch
2 Suggested Answers
SOURCE:
SOURCE: I am hooking up a
1) Look at screw color.
New device has brass screws on one side, and 1 silver screw for each switch located on other side of device.
Hot wire goes to brass screw.
Wire to fan goes to one silver screw
Wire to light goes to another silver screw.
Wire to heater goes to another silver screw.
If you do not have a wire for each individual Load, then you will have to add wiring.
2) Electricians don't guess, they test.
Separate wires for testing.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire.
Hot wire connects to brass-colored screw.
If any wires on old switch was connected to same Hot wire, then also connect that wire to brass-colored screws.
Hot wire is identified.
Test Hot wire to each other wire in box, except bare ground.
Tester lights up on Neutral wire. Neutral wire will NOT connect to this switching device.
Next, connect one of the remaining wires to a silver screw.
Turn power ON.
Flip switch to see what Load that wire controls.
By process of elimination, add wires to each silver screw and test each by flipping switch.
Breaker will trip if you connect Neutral to silver screw.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on circuit.
Posted on Jan 10, 2011
Wiring diagram for levinton 1755 switch
http://waterheatertimer.org/How-to-wire-switches.html#triple
Triple switch wiring with neutral in box and neutral in light fixture
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 11, 2014 | Leviton 003-1755-W Three Rocker Switches
I need to find leviton 1755 in brown
You could use 3 brown single-pole despard switches
Otherwise I cannot find source for triple rocker in brown.
Apr 30, 2011 | Leviton 1755 Triple Rocker Switch Decora
How do i wire a miniature rocker switch red/brown and black wires
Any wire that is colored is hot, except for green and white, which is ground and neutral, If you have a line coming in to your switch, and 3 loads going out, red, brown, black, then those should be the 3 lights. The white wire will be connected to white, and the green to ground. If you don't have 4 colored wires, then you have 1 switch too many. Let me know if this is making sense.
Apr 14, 2010 | Leviton 003-1755-W Three Rocker Switches
I'm using a Leviton 1755 combo 3 switch for a bath light/fan combo and then onto a vanity light. Basics: wires from ceiling light/fan: black, red, white, ground. Wires to vanity light: black, white,...
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Feb 22, 2010 | Leviton 003-1755-W Three Rocker Switches
3 single poll rocker switch alternative wiring
You never hood the neutral to the switch. The neutrals are always tied together and pushed back into the box. You only hook the line (power) & load (light) to the switch. Of course you also hook the ground to the switch.
Jan 09, 2010 | Leviton 003-1755-W Three Rocker Switches
Not sure how to wire this switch
Switch will have a commom terminal that the hot wire connects to.
The other three terminals are for the devices -- light, fan and other device.
The white wires should be the grounded wire returns for the circuits unless they are identified by color tape to be hot line side of power.
Be careful of the grounded side of circuit, can shock or kill, treat all wires as being energised. If you are not sure, use a electrical tester,
or get help.
Feb 28, 2009 | Leviton 003-1755-W Three Rocker Switches
Leviton 1755 Triple Rocker Switch Decora Logo
47 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
boomanfoo
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
