Drier does not fully dry clothes. Filter is clean but difficult to clean the part where the heat exchanger is. How to do this?
SOURCE: Have to run dryer twice to get clothes dried
also check the exhaust outside of the house, i had birds nest in mine
SOURCE: Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
SOURCE: Whirlpool AWZ-7813 won't dry - no heat
it will either be you element or the thermostats that have failed.
SOURCE: my whirlpool awz7303 is not
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
