SOURCE: Can't turn on the fog lights
hi from uk if you are meaning rear fog light/s ? they will be on the switch that has a picture of lamp with horizontal lines ? these will only work with headlight on also if you are meaning front drive/fogs then the same goes for these ie a similar switch near to lights switch or you may have to turn on h/lights then pull outwards the actual switch as on uk cars? the idea being if weather conditions req fogs then h/lights must be on also preventing driving on fogs only and no obligatory side/tail and h/lights here in uk hope this assists you locating switch ? wish you merry xmas
SOURCE: 2003 hyundai elantra gls abs/tcs light on
unless you can discover what DTC (Diagnostic Trouble Code) has been recorded/set in the control module, it's anyone's guess.
Testimonial: "thankyou"
SOURCE: 2002 Hyundai elantra driver side turn signal not working outside
This simply means that the front driver side turn signal bulb has failed. Replace it.
Testimonial: "Thank you I will try that"
SOURCE: 2002 hyundai elantra gls . low idle speed, check
Did the 'Check Engine' Light come ON? Whenever the 'CHECK ENGINE' light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on. You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE and perhaps eventually fix the problem.
SOURCE: 2003 Hyundai Elantra GLS. Check engine light, code PO133
Did you use a aftermarket O2 sensor or a genuine Hyundai one? If it's an aftermarket one it may be bad or not as good as the OEM one. See here for more details and other potential causes: P0133
