My compreProblem with Craftsman 33 gal Air Compressor 6 hp Horizontal k Oil Free Pumpssor all of the sudden got really loud and sounds like a bad exhaust leakl. still builds pressure but takes longer. Also the regulator is leaking now. Any help would be great!
SOURCE: I have a Craftsman model 919.152932 33 gal
Sounds like the reed valves in the head failed. you need to replace the head (usually cheaper to get a new compressor)
Testimonial: "I hated to throw away an otherwise perfect condition compressor, but I had a feeling that was going to be the answer.Thanks for your help."
SOURCE: Craftsman 3 gal., 1.5 hp air compressor: won't
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
SOURCE: Craftsman 1 HP 4 Gal air compressor runs and
Cold weather will freeze the water the compressor normally makes and this can prevent the switch diaphragm from releasing.... also drain the tank
