If your radio will not pick up radio stations then there is an issue with your antenna connection either behind the radio or with the vehicle antenna connection itself.
Jun 22, 2015 - ... Asia, and elsewhere: instead of every station having its owntransmission ... Nautel is bringing the same concept to FM-HD as part of its "HD ... Ismy radio broken? ... Inovonics expects to go into full-production mode on the Justin 808 in ... As it has been for the entirety of HD Radio's history, I guess it'll be ...
Microsoft WindowsLearn about solving problems with trying to play FM radio stations in Windows Media Center. ... Why doesn't my FM radio play? FM radio may not play for one of ...
There isn't an FM radio built into this unit. So maybe you are trying to get internet connected radio stations to play perhaps?
You can do a search for a program called a "radio Aggregator" which allows you to receive radio stations form all over the world. or you can just go to your favourite radio station an see if the stream live music over the web.
This is a radio station in England that I listen to via the internet from time to time, but most big radio stations stream these days.
you can look for a radio shop to repair the cd player it would be cheaper to install a aftermarket radio they do have kits if you have steering wheel controls
Contact the satellite radio company and ask them to perform an update to the radio.
This exact issue happened to 4 of our vehicles within a 60-day period and having them perform an update resolved the issue in every case.
this is how i preset my stations, im not sure if you have done this before.
fm can save 20 stations and am can save 12
1] chose your desired station
2] press & hold the play/memory button until P01 pops up and flashes
3] to save the station, press & hold the play/memory button
if you'd like to save another station, then repeat steps 1 & 2,
then press the play/memory button again until P02 pops up,
repeat step 3.
to listen to your preset station, all you have to do is press the play/memory button.
i have the exact same problem. i bought a fm transmitter, so i need to tune to a unused fm station in my region wich i cant do because the audi concert tunes up automatic and skips the unused stations ... HELP !
You are combining two different things together.
Firstly you cannot play the Radio without headset and for just playing the radio you need not any Radio Code. Hopefully you need radio code to play Visual Radio. In that case you can play it even without knowing the code. Go to Station Menu in your GPRS connected N70 and then select the Country and the nearest location for getting a list of all FM stations alongwith Visual Radio information, if available.
Alternatively you can get more information about the Visual ID at www.visualradio.com
Just bought the same unit but the instruction manual was double dutch. After messing around for a while I managed to do it like this. Whe the unit is set to DAB, Press the Sel+/TU+ or the Sel-/TU- button on the unit (not the remote) until the DAB station displays and then press the Select CH+ button again on the unit. Wait a few seconds while the word "tuning" is displayed and that station should now play. To save the station as a preset do this. When the station is playing use the remote and press the PRG/MEM button once. Then press the number for which preset you want that station to be. The station will be saved. EG to save Radio 1 as Preset station 1, play Radio 1, Press PRG/MEM, then press number 1. After that whenever you press number 1 on the remote Radio 1 will play. Do the same with any other station you wish to save. To save station 10 press the 0/10 button on the remote. To save station 11 press 10+ then 1, 12 is 10+ the 2 etc. Good luck Dopeyemma
