I tried to plug different chargers in and change the places i plug the charger in but nothing words. my phone is able to die and it won't charge.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
SOURCE: my nokia E5 won't charge, I've tried another charger but still nothing
can you see the pin in the charger socket? these can get bent, other wise looks like your charge socket has come free, from the board
SOURCE: Nokia 3250 charging problem
you must change the charging block /base pluck or go to the service provider will do it for you. advice by dogy.
SOURCE: my nokia n95 won't charge,
First check the charger by using it to charge a different phone to determine if the charger is functioning fine. After doing this check the battery is properly installed if both options above are in good condition then sorry to say but the central board on your unit is probably bad and will need replacement.
the central board is the main component of the phone and acts as thee brain of the device, all functions go through it. When you purchase a new battery the unit should at least come on even if the charging function does not work.
best refer it to an expert to determine if the entire board is spoilt or just the power segment of the board.
Hope this support has been helpful?
Thank you for visiting FixYa.
