I started to take out the three bolts on one side of the skid plate and it seemed like there was some weight exerted on it. Just dont want to create a bigger problem for myself
Skid plates would not be holding up the transmission there should be mounts with rubber inserts mounted to the frame that hold up engine and transmission. If the mounts have gone bad it the engine and/or transmission could have sagged down which would cause it to possibly touch the heat shield. For your own safety I would suggest to put a jack stand undneath the transmission or reenforced part of engine or rent and engine hoist from your local auto parts store and hook it up to the top of the engine to hold the weight of the engine. Renting an engine hoist is cheaper than a hospital trip.
SOURCE: catalytic converter
HI, this guide will help you with this replacement.
Step1
Lift your jeep. Unfortunately, the catalytic converter
sits about midway down the length of your jeep, so lifting one end or
the other will not do. Ramps are your best bet to get you within reach
of the parts when working from home. Luckily, this is usually the
hardest part of this repair.
Step2
Be patient with the bolts, as they are often hard to remove due to size
and awkward placement. You may have to drill or saw bolts to remove
them. With this in mind, you should pick up new bolts, nuts and seals
for your replacement project.
Step3
Buy a catalytic converter specific to your jeep to avoid extra work. A
generic part must be welded into the jeep, while a vehicle-specific
model comes pre-welded to the proper pipes for easy bolt-on
installation.
Step4
Remove the 02 sensor (with an O2 wrench) before unbolting the catalytic
converter. Then, you should remove the pipe connecting the sensor to
the converter. Depending on your exhaust system, you may have to remove
more pipes before you unbolt the converter from the muffler.
Step5
Replace the old catalytic converter with a new one. This should be the
easy part, as you simply bolt the new part in place.
Step6
Reattach the exhaust pipes
and 02 sensor, and the basic job is done. Make sure you replace any
cracked or rusty pipes while you have the exhaust system apart.
Please rate and god bless:)
SOURCE: removing oil pan on 2003 jeep wrangler with auto trans
use a pair of plyers and pull down on the plastic it should just be slid on the bolt take the tranny lines off the piece plastic first
SOURCE: Replacement of catalytic converter 98 Wrangler
you don't have to remove any hangors, but some times its easier. After getting it all off, it goes back on the same way. I prefer welding the pipes shut, but its not neccessary, just make sure the U Clamps you are using are good ones and tightened good.
tepfy
SOURCE: replace 1995 jeep wrangler catalytic converter
If it has flanges on both ends, just unbolt it and replace. If it has welded pipes you will need to cut it off and use adapter sleeves and clamps. Really not rocket science...at worst, you may need to remove the hangars on the rear portion of the system to get enough room to install.
SOURCE: '88 Wrangler w/4.2 & Auto Trans. Cat Convert
I hope the last owner did not take out the smog pump.
Check under the hood,look for a smog pump.
The smog pump provide more "fresh air" into the cat. in return you get a cleaner exhaust.
In some state,the tech can fail smog check because of missing emission part(s)
The pipe is pretty long and it's well constructed.
try to cross Carquest AT167 Air Tube Kit at you local part store.
Place an oil drain container under the oil pan. Loosen the drain fitting with a wrench until oil drains from the pan. When oil is done draining, tighten the drain fitting.
Place an jack under the transmission to support it. Remove the pressure on the transmission crossmember.
Place the new gasket on the pan and push the new oil pan into place. Finger tighten the oil pan mounting bolts to hold it in place. Tighten the bolts with a torque wrench to 18 ft-lbs. DO NOT OVER TIGHTEN THE BOLTS! Doing so will cause the gasket to deform and create leaks!
Attach the oxygen sensor socket to the exhaust pipe with a wrench.
