Turntable and the fan that comes on when microwave function fine, the lights under unit do not work or the exhast fan but control panel shows on and off.Turntable and the fan that comes on when microwave function fine, the lights under unit do not work or the exhast fan but control panel shows on and off.
You can't post conmments that contain an email address.
If your turntable is not going around you may have one of two problems: the coupler under the glass tray may be worn and in need of replacement or the turntable motor needs to be replaced. Hope this helps.
We see (and repair) this
a lot. The problem is on the control panel, which
we regularly repair nationwide
by mail for $39.95 postpaid.
At
our Web site, you can get details of our
service, plus we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
This light failure often
occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
The lights can can be
inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly
affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
free information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
Your hood TCO may be shorted. It should read normally open.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.Or if you've recently had a blown cooktop light, it may have damaged your fan control on the circuit board.
by mail for $39.95 postpaid in about a
week or so.
At
We're
week or so.
At
inoperable or stuck on or no bright, too. Sometimes this will similarly
affect the exhaust fan operation or inside light, too.
information & help.
We're
we regularly repair nationwide by mail for $39.95 postpaid in about a
week or so.
At
our Web site, you can get details of our service, plus we have a video
full model number from the tag on the unit) for more information & help.
We're
week.
At
The lights fan can be
affect the exhaust fan operation, too.
We're
week.
At
We're
week.
At
Sometimes this will also
affect the exhaust fan operation, too. The lights and fan can be
inoperable or stuck on too.
full model number) for more information & help.
We're
thoughtful rating of our answer.
The unit will work just fine on the counter, but obviously the lights underneath won't show and the exhaust fan won't be of much use. Otherwise, it's perfectly ok!
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
