I tried this and it worked fine
FACTORY RESTART:
A Factory Reset will erase the connection between the Display and the Thermo-hygro sensor and allow a fresh connection to be re-established. It is recommended to have the display and all sensors 5-10 feet apart for this restart.
ENTER PROGRAM MENU
Press and hold the SET button until you enter the program menu. Press and release the SET button until you see 'rES oFF' flashing.
FACTORY RESET ON
Use the UP ARROW key or DOWN ARROW key to turn rES on.
CONFIRM & COUNTDOWN
Press the SET key to confirm and a countdown timer will begin counting down from 127. When the timer displays dOnE, you must remove the batteries from the display for 10 minutes
REMOVE BATTERIES FROM THERMOHYGRO AND RAIN
While the batteries are out of the display, also remove the batteries from the Thermo-hygro sensor and the Rain sensor. Wait 15 minutes.
GENTLY KEY THE WIND SENSOR
Gently key the wind sensor one time to activate the sensor.
INSTALL BATTERIES INTO THERMOHYGO AND RAIN
Insert fresh alkaline batteries into the Thermohygro sensor and Rain sensor make sure to check polarity with the markings on the battery cover and inside the battery compartment. Wait 2 minutes.
INSTALL BATTERIES INTO DISPLAY: Insert fresh alkaline batteries into the Display. Make sure to check polarity with the markings inside the battery compartment
15 MINUTES: Wait 15 minutes for the outdoor weather data to display. If the outdoor data displays dashes after waiting for 15 minutes, repeat the steps of restart.
AZ Road Runner
