Televison & Video Logo
Joel Mallory Posted on Sep 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stuck on video 1 - Televison & Video
francoise cleofas
Level 3:
Genius:
  • Televison & ... Master 2,432 Answers
  • Posted on Sep 16, 2012
francoise cleofas
Level 3:
Genius:
Answers
2432
Questions
0
Helped
298332
Points
6852
Tried with unplugged and re plugged doesn't work?. check for stuck AV button in the tv panel.
Problem need help
There are several videos on youtube about how to remove stuck disks. I'll post 1 for you here.
How to remove stuck discs in your ps3 first generation
Screen stuck empowering
Dear frnd,
There are many reasons to have video stucks problem.
1) Low Ram ( need to increase Ram Memory)
2) Outdated Player ( Need to update the palyer with latest version)
3) Player not support that video format( Need to download good player like KMP /VLC etc..)
try it..
Tryin to connect this ps3 ultra slim to this toshiba tv, everything is connected i reset the settings so its not stuck in hdmi an no luck getting a picture
What are you hooking it to on the back of the tv, aux., video 1, video 2, ? If you hook it to video 1 on the tv then you have to go into the menu on the tv and change it to video 1 or ant.
2answers
The machine used to work but now when it powers up it has an error message "stuck switch" any advice?
Hello: stuck switch means, a microswitch from the joysticks or
push bottoms or the coin door switch, check 1 by 1 manualy
if you don't hear a click after you push it, that switch is stuck.
Good luck...
Miguel.
40" samsung lcd stuck on video 1 (rcs/composite video)
i would say the main board is toast. time for a new one. try www.encompassparts.com, go in through the guest log-in
Can't change FM input mode! Stuck at analog...
Tuner is only analog. As for the Video 1 input you need to go into the menu and change it to the digital port you want to use (optical, coaxial or HDMI) you can set only one input to each digital input port.
Toshiba television will change from tv/video mode to
I would check to see if the Input button is stuck on the front panel of TV. If it is not stuck then it is probably still bad. Tactile switches are notorious for failing in this manor. The only real fix if it is not stuck down is replacing the switch.
I hope this helps,
Skyassoc
TV is stuck on video 1?
You probably have a replacement remote. It will need to be reprogramed to your tv. You should have instructions that you got with the remot. Otherwise call your TV repair man and he can probably "walk" you through it over the phone.
No picture, stuck on Video 1, volume self-adjust to maximum
the tacticle (micro switches)on the front of the main chassis have most likely gotten wet at some time,I suggest replacing them all.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
