I AM PHOTO GRAFER AND MOVIMAKER
Https://youtu.be/S49oXRLnx3c
This is a very simple solution for those who are facing this error
"This Battery Cannot Be Used, Choose A Battery Designated For Use In This Camera"
Mostly this error occurs in Nikon cameras. I found out the very simple and easy solution to fix it.
All you have to do is just clean your battery terminals, or take a needle and narrow them so they can contact
your camera directly. this mostly happens when one or more of the terminals are not touching in the camera,
please watch this video and leave a comment regarding to this problem, i hope this will solve your problem.
Subscribe my youtube channel "SolveIT" more for DIY stuff
Thanks
Well what what dont you understand?
SOURCE: Battery Issue
This battery cannot be used. Choose battery designated for use in this camera."
SOURCE: brand new D60: This battery cannot be used.
yep ...look in the menu ...of the camera ..and select the type of battery u are using ..there are 2 kinds of batteries ...one of them are alkaline ...and the other I'm not sure ..probably nickel or lithium ..or something like that ...anyway there are choices there ..and you just have to try 'am one by one ...
it will also accept only high quality non chargeable ones ...so ..even if they work in other device ..in this kinda cameras it will see 'em as empty if they arent great in quality and amperage ...
SOURCE: Nikon D3100 brand new. I
The fault could be either defective batteries or a defective camera. All you can do is to try a full initial battery charge (24 hours) and if that doesn't work return the camera to the retailer for a refund or exchange.
SOURCE: I am having a Nikon
Your battery may be worn out and is unable to get re-charged. Buy a new battery for your camera, or try your battery in a matching camera to verify that it is depleted, if so try a new/other battery in your camera to verify that you need a new battery.
This battery cannot be used Choose battery designated for use in this camera
