SOURCE: No response from printer
restart the print spooler service from "services.msc"..also check if your printer works in safe mode or not,if it prints there you must try stopping firewall settings & then try to print..
also delete the pending items to print from the list first...
it it helps,rate my suggestion..
SOURCE: BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
SOURCE: Just purchased the MP560 printer
The printer must be cleaned where the cartridge rests as this must be soiled with ink residues. If this does not help should be checked by removing all the cartridges and clean them one to one place back to the printer and after testing. It is easy to perform this cleanup must use a "q-tip "and carefully try to clean all cartridges and all you can see you have old ink as this stand the mechanism and do not allow the cartridges to work properly. Luck!!!
SOURCE: When printing, print is has irregular & has
you can flush the printhead on running water.
and have a mixture of ammonia and water solution. Soak the printhead and leave it overnight. This will unclogged residue in the printhead.
it will work again as good as new.
