Lands Phones Logo
Posted on Dec 26, 2008
Phone has a dial tone but will not dial
Phone has a dial tone but when you dial nothing happens. It is almost as if the keypad is disconnected. When you dial you can't even hear the touch tones. This has happens on about 8 of the 12 phones I purchased. What a good deal.
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on Dec 29, 2008
Anonymous
Contributor
Level 1:
Answers
24
Questions
Helped
9479
Points
31
I would first verify that the line is good. Take a known good corded phone. YES corded phone !!! and try dialing with it and make sure it dials on the line every time. Also make sure that the Pulse/Tone setting is set for your service( there is still a few area without Touch Tone belive it or not)
Once you verify that the line is ok check each phone and take the defective ones back to where you bought them.
Comdial Executech 6714x-PG We have nearly 20 phones. All of them get a dial tone but nothing happens when you press 9 to dial out, none of the phones will dial out. Calls can come in only. Thank you
they are either restricted or what you are hearing is intercom tone and not dial tone. the phones may be set to dial out from a diffrent line grop as well have you tried dialing 81 82 instead of 9 and see what happens
15helpful
Samsung SGH D900I- cannot turnoff keypad sound
The steps are outlined in the article below:
D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
To change the dialing display font type follow the steps below:
  1. From the standby screen, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Display Settings (3)
  4. Select Dialing Display (6)
  5. Select Font Type (1)
  6. Highlight either Normal or Theme, using the navigation keys
  7. Press the left soft key to Save the Dialing Display Font Type setting
To turn off the keypad tone follow the steps below:
  3. Select Sound Settings (4)
  4. Select Keypad Tone (2)
  5. Highlight Off, using the up navigation key
  6. Press the left soft key to Save the Keypad Tone setting
Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Dial tone hanging
There are two wires going to your phone. Inside the wall jack, switch the red and green wires and the keypad should work .
Dial tone
I disconnected the RadioShack phone/answering machine and plugged in an old phone. At first I didn't get a dial tone, but in a minute or so, I did get one. I doublechecked the connection with the incoming phone jack. (I had checked this before, but didn't see anything wrong.) Again, I didn't see anything wrong, but maybe that did it. Also, when I disconnected the RadioShack from the incoming phone jack, I disconnected from my computer (I used to have dial-up connection).
Don't know which of my actions worked, but now I have dial tone on Radio Shack.
Hoooooooray!!!!
2answers
Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Display blank, no keypad tones, Emerson EMG900 phone
you must use a ac adapter which the phone doesnt come with or 3 double A batteries
Phone repair
the links tat r there inside the phone are shorted as they r very thin threads like..just go to a repairer and he will resoulder the links and the problem will be solved..for temporary work just open the phone and remove all dust ..mostly keypad will start working
9helpful
7answers
Can't get to voicemail
Change the DTMF found in phone settings (Initial Set-up) to either short or long. When this is set to off, the voicemail cannot pick up the numbers you type.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
