I use a sonic firewall and use the vpn to get into my network. It works fine with wi-fi hotspots. I'm trying a verizon 3g card and it gets on the internet and even says "connecting to network" but I can't access internal machines. I noticed that it is not assigning me an internal LAN IP
SOURCE: cisco vpn will not work with verizon service now after we got a new modem through verizon
Verizon Home DSL service uses a special filter that prevents ALL incomming connection including web, email and VPN hosting from a home connection. Business internet does not limit this, and I don't believe FIOS blocks it. If you have verizon home, there's nothing you can do. If you're just trying to connect to a home machine, you can try something like gotomypc, or a free alternative like teamviewer.com or logmein.com.
If you don't have verizon home dsl, comment back with what service you do have, and we can try some other things.
Steven
SOURCE: di-524 dlink; wireless laptop connects but no internet or network
Your wireless card is dead, replace.
SOURCE: VPN Access does not work
Use should add arp proxy setting as the following:
Go to Interfaces and then click on PPTP/L2TP server from the PPTP/L2TP Page go to the Add ROute Tab.
Allowed Networks should be : All Nets
under Proxy Arp you have 2 Boxes:
One is: Available and the other is Selected.
Under Available click on LAN and move it to Selected.
now save and activate and it should work.
SOURCE: my verizon p5750 internet pc card not connecting to WAN on my DIR-450 wireless router
Download the new firmware for your router. Should be able to locate it on the D-link site. Log into the router and let it update. Instructions on how to do this are in the manual or online. This should solve any connection problems with your router.
Did you solve this one,
