The plastic around the AC power port is broken and is hard to recharge. If I get a new palmrest, is it very easy to replace?
SOURCE: sony vaio vgn cr200e drive
Western Digital Scorpio WD5000BEVT Mobile Hard Drive - 500GB, 2.5", looks nice. I haven't seen any larger yet.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4322423&CatId=1277
SOURCE: sony vaio vgn series doesn't turn on no power
You should try another ac adapter.If that does'nt work the power jack where it plugs in may be bad or the power board under the power button is bad.You should try another ac adapter first though.
SOURCE: charging problem in sony vaio VGN-N220E
sounds more like your dc jack(where you insert your plug into the laptop ) is going bad. If you have a multimeter the first thing to test would be your charger to make sure it isnt faulty. If the charger is fine then it is most certainly the dc jack. Replacing the dc jack is best to be left to someone who specializes in that kind of repair but if you know how to solder it may be something that you can do yourself. click here for more info on dc jacks.
SOURCE: I need to replace my sony vaio VGN-N series laptop
Here is some instructions:
www.yboyandrei.com/VGN-N
Please rate me.
Thank you.
SOURCE: Need service manual or instructions on replacing
The hard drive is inside of the laptop and not accessible from the outside. The way to get to the hard drive is to take out all the screws from the bottom of the laptop, take the keyboard out and there may be some screws there that need to be removed. The dvd drive needs to come out and where the dvd drive normally is, check for screws there.
At this point you can remove the top cover assembly and you will see the hard drive. Remove the screws that are holding the hard drive in place and then it will come out.
Testimonial: "Thanks I realize that the unit needed to be seperated however without a service manual there may be some important tips that could be missed."
Because this plastic is broken, the charger doesn't sit exactly like it should.
