Makita EM4251 16" 4 - stroke String Trimmer  Logo
Violet Hammon Posted on Sep 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What kind of oil do I put in my 4 stroke
Not fuel. I am wondering about oil
CHICO
Level 2:
New Friend:
  • Expert 90 Answers
  • Posted on Dec 28, 2013
CHICO
Expert
Level 2:
New Friend:
Answers
90
Questions
0
Helped
20943
Points
146
10w30 is a base line oil for 4strokes. Hope that helps!
2-stroke or 4-stroke?
Well, if it has an oil drain plug and/or a fill plug for oil, It's a 4 stroke. If it has an odd shaped muffler/resonator, it's a 2 stroke.
Oct 14, 2014 • Garden
Is it 4 stroke or 2 stroke
Does it have a dipstick that indicates the amount of oil?
If it has, it is a 4 stroke and does not require an oil/fuel mix.
If it does not have a dipstick, it is a 2 stroke and will require a mix of oil and fuel.
Without knowing anything about your genset, I would think that it is a 4 stroke.
A 2 stroke motor would deliver the power too high in the rev range.
2answers
What sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Judging from what discription you are giving me I would say it is a 4 stroke, so make sure you have either sae 30 or 10/w30 oil in crankcase where it says oil and petrol (gas) in the other tank. 2StrokeJim
Oct 27, 2011 • Garden
3helpful
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 • Garden
2helpful
What oil should i use
Use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell. If in a hot area like Texas or New Mexico go with 20w50.
Use TWO STROKE ENGINE OIL in the pump. If not using an automatic oil pump, then mix the gas and oil 32 to 1. That equals 4 ounces of TWO STROKE ENGINE OIL to one gallon of gas. NEVER use motor oil in the gas. Only two stroke engine oil.
1helpful
Want to no if it takes petrol on its own when fueling or 2 stroke oil added to it aswell
i guess your asking if its a 2 stroke or a 4 stroke right ?
2 stroke engines dont have an oil filler cap , just a fuel filling point, the fuel used in a 2 stroke is just normal unleaded (aus) but you mix 2 stroke oil in the fuel before filling (about 50/1) or whatever it recomends.
4 stroke uses the same fuel but you dont mix the oil with the fuel , it has its own filler point for oil , however you must use a 4 stroke oil with these .
hope this is what you were after.
May 01, 2009 • Garden
4 stroke oil filter question
i always just put some on the o-ring before i put it back in but no, you dont need to have oil on it
Oil filter
i always just put some on the o-ring before i put it back in but no you dont need to have oil on it,
Top Makita Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Makita Measuring Tool and Sensor Expert? Answer questions, earn points and help others
