If Wii gives Disc Read Error, first step you need to check is to
try another disc or clean the exisitng disc. This will confirm that
problem is with either Wii or Disc. If the console itself is giving
disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,
that will show step by step information to fix the problem yourself. It
also gives information on fixing many Wii Related Problems, so its a
kind of Wii Problems Reference Fix Guide
Unable to Read the Disc / Disc Could Not Be Read
Situation:
System displays either error message "Unable to read disc" or "Disc could not be read"
What to do:
This message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
If the Wii console is laying flat, verify that the system is not placed upside-down. The game disc slot should be above all three buttons and the SD Card slot.
Verify that the disc is being inserted properly.
If the console is placed vertically, the disc label will face to the right.
Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically (learn more)
If the console is placed horizontally, the disc label will face upwards.
If the problem occurs with only one game disc, there may be a problem specific to that game. Click here to check our list of specific game issues.
Situation Not Resolved:
If only one Game Disc displays this error message, it will need to be replaced. Click here for Game Disc replacement options
If the error is occurring with most or all Game Discs or all of one type of game, then this indicates a problem with the system. The console and one or two example discs will need to be sent in for repair. Click here to begin the repair process.
What error messages that appear on your screen? If you see;
1 Disc read error or unable to reading disc, there is a problem with the laser lens, it can be happen if the lens is unclean, e.g. dusty, try to Cleaning the laser lens using disc cleaner. if you technical, try to make adjustment of the lens or replace the laser if necessary.
2 Error #001 - #002, you have a problem with wii system firmware, you need to updating wii firmware. If you have softmod/homebrew installed see here; http://e-arena.blogspot.com to get more help.
Hope i helped you. Thanks for using ' Fixya ' and have a nice day!!
Call nintendo, if there is something in the USB port in the back of the system then take it out, it could cause freezing with out disc. If all of your disc are not playing ( Unable to read disc please refer to the wii operation manual ) its a problem with the disc drive in the system, set up a repair.
If Wii gives Unreadable disc, first step you need to check is to try
another disc or clean the exisitng disc. This will confirm that problem
is with either Wii or Disc. If the console itself is giving disc read
If Wii gives Unable to read Disc Error, first step you need to check is to try
"Unable to read the disc" / "Disc could not be read" / "Eject the Game Disc" Error Message.
If you are getting one of the above error messages:
Ensure that you are properly loading a Game Disc.
If your console is placed vertically, the disc label will face to the right.
If your console is placed horizontally, the disc label will face upwards
If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures
If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options.
I had the same problem, I take it you have a modded wii(chipped), if you use a backup disc it is of a lower quality then original discs, the wii gets read errors without you noticing and tries to read those disc areas again sometimes suceeding and the gaming goes on, sometimes it fails, and a disc read error occurs.
Over time the dvd assembly will take some damage it will loose it rigidity it once had and the wii stops reading discs.
The problem gets worse if you have standing up, so first thing si to flip it down and try.
Otherwise you (or someone you trust) will have to open the wii and adjust the lens sled so it wont flap as much up and down.
Hope this helps..
